andy.b 0 Posted April 26, 2005 hello lads, i have had this problem on my car for a while and its getting abit louder. when i am slowing down "approaching a junction" you can hear a rubbing noise on both sides of the front top end of the car "its like when a train goes ch ch, ch ch, ch ch" but does not sound like a train. the sound is like its in timing with a point on my wheel when it goes round. STRANGE explanation i no! i have 17's, Koni coilovers, pads + discs, new wheel bearings, track rods, ball joints and sub-frame could this be the top mounts Quote Share this post Link to post Share on other sites
2cc 0 Posted April 26, 2005 If its when you're braking then probably a worn pad Quote Share this post Link to post Share on other sites
andy.b 0 Posted April 26, 2005 sorry, its not when i am braking. just when i am rolling to a stop without braking Quote Share this post Link to post Share on other sites
pp137 0 Posted April 26, 2005 Hi i have the same problem with my car, jus got the car back from the mechanic today to hear some very bad news. Apparently the driveshaft has gone, thats why you hear the noise. I not sure if he chattin rubbish or what but gonna take it somewhere else to get the whole car checked out. Quote Share this post Link to post Share on other sites
andy.b 0 Posted April 27, 2005 you no what mate, i thought it could have been the drive shaft as well. ill take my car to dubsport and get it checked out. as soon as i find out what it is i will keep you updated Quote Share this post Link to post Share on other sites
Louie Lungbubble 0 Posted April 27, 2005 Same thing's happening to me. Mine was diagnosed as a fecked rear mount causing the engine to sag and something to touch on something else. My noise dissapears under acceleration, due to (I think) the engine lifting away from the sagging mount. If yours is the same, don't worry about getting it fixed, just drive ALL the time like you were late for a date with Kelly Brooke :) Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted April 27, 2005 Is it like a metal on metal rubbing noise. If so I had a similar issue and it might be the weights on the drive shaft come loose. If that is the case you can just cut it off!!!! Quote Share this post Link to post Share on other sites
andy.b 0 Posted April 28, 2005 yes mate it is like a metal to metal rubbing noise but it is not very loud. i have had all my engine mounts and gear box mounts checked out and their all in perfect working order. i will get dubsport to check out my drive shafts. cheers! Quote Share this post Link to post Share on other sites
Neil L. 0 Posted April 28, 2005 Could it be warped discs? Quote Share this post Link to post Share on other sites
alan_edward 0 Posted September 27, 2005 I seem to have this problem too, metal rubbing noise when slowing down. Please help. Alan Quote Share this post Link to post Share on other sites
-Neil- 0 Posted September 27, 2005 i have this problem too, any more info on this? Quote Share this post Link to post Share on other sites
khurrado 0 Posted October 10, 2005 i get the same, very scaring metal scraping sound. Is it safe to cut the weights off? Quote Share this post Link to post Share on other sites
Brieve 0 Posted October 20, 2005 I have Been Driving mine without the weights for a few months now. Not noticed any problems from the fact that they are off. If the guy before me that owned my baby had keep her serviced then I dont think I wouild be having as many problems as I do now. I honestly dont think the vibration dampener will cause any problems. If you are interested in getting it fixed you have to get a new drive shaft. Also you can take it off super easy if you pop the outer CV joint off it slides out. Quote Share this post Link to post Share on other sites
Henny 0 Posted October 20, 2005 see HERE for details on the driveshaft damper/weight thingy and how it should look and looks when it's boogaaarrddd.... ;) Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted October 20, 2005 Is it like a metal on metal rubbing noise. If so I had a similar issue and it might be the weights on the drive shaft come loose. If that is the case you can just cut it off!!!! THATS WHAT HAPPENED TO MINE, SO I TOOK THE RUBBER OFF AND FILED IT WHERE IT BELONGS,,, IN THE BIN!!!!!!!!!!!!!!1 :lol: Quote Share this post Link to post Share on other sites
