KarmannVR6 0 Posted May 4, 2005 Ever scine ive had my vr its never showed the outside temp reading on the MFA. It shows mpg, average speed etc. but ends with the oil temp. Didnt even realise it was ment to show outside temp. until i read a post on here. Is this normal? Quote Share this post Link to post Share on other sites
daves16v 1 Posted May 4, 2005 Yes, it's normal. Quote Share this post Link to post Share on other sites
KarmannVR6 0 Posted May 4, 2005 How do i get it to show outside temp? Quote Share this post Link to post Share on other sites
daves16v 1 Posted May 4, 2005 Stumped on that one. Outside temp is the last displayed before it starts again. Quote Share this post Link to post Share on other sites
KarmannVR6 0 Posted May 4, 2005 Mine ends with oil temp. then starts again, never shows outside temp. Odd. Quote Share this post Link to post Share on other sites
ben16v 0 Posted May 4, 2005 the sender is on the driver side air duct to the brakes worth checking if thew wiring is in tact Quote Share this post Link to post Share on other sites
KarmannVR6 0 Posted May 4, 2005 Thanks. Theres a blue conector on the inside of the driver side wing with no sensor in it. Is it related? Quote Share this post Link to post Share on other sites
Henny 0 Posted May 5, 2005 yup, that blue connector should connect to the sensor in the lower bumper grill on the drivers side... have a look under the indicator and you'll see a metal panel riveted in behind the grill, there should be a sensor in there that the connector should attach to. If it's not there you'll need a new sensor. The MFA will skip the outside temp display function completely if the sensor is either disconnected or dead. 8) Quote Share this post Link to post Share on other sites
Whitedog 0 Posted May 5, 2005 Do all models show the outside temp or just vr's. My valver ends with oil temp. Always thought it a bit odd as me golf's both had outside temp. Quote Share this post Link to post Share on other sites
LJ 0 Posted May 5, 2005 Ah, that would be a new sensor for me to then :-( Quote Share this post Link to post Share on other sites
Henny 0 Posted May 5, 2005 Whitedog, yup, all of 'em should have it... Good news is that the sensor isn't expensive... 8) Quote Share this post Link to post Share on other sites
