billinjah 0 Posted May 19, 2005 are there any complications involved in these jobs? are there marks on the charger so its lined up properly? i take it the silencer box is a pita to get out looks tight! Quote Share this post Link to post Share on other sites
dinkus 10 Posted May 19, 2005 Erm, how to change what exactly? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 19, 2005 Changing belts on a G60 by the look of it.... Quote Share this post Link to post Share on other sites
joebloggsVR69 0 Posted May 19, 2005 Angel eyes? :lol: Quote Share this post Link to post Share on other sites
Blown 0 Posted May 19, 2005 Your underwear? [schild=9 fontcolor=000000 shadowcolor=C0C0C0 shieldshadow=1]give[/schild][schild=8 fontcolor=000000 shadowcolor=C0C0C0 shieldshadow=1]us[/schild][schild=7 fontcolor=000000 shadowcolor=C0C0C0 shieldshadow=1]a[/schild][schild=4 fontcolor=000000 shadowcolor=C0C0C0 shieldshadow=1]clue![/schild] Quote Share this post Link to post Share on other sites
Henny 0 Posted May 19, 2005 The clue was in the second bit of the title... I've edited the main title to reflect what the thread's on about... :roll: Quote Share this post Link to post Share on other sites
Henny 0 Posted May 19, 2005 which belt do you mean? The small one on the charger, or the large on which drives the waterpump and alternator too? If it's the big one, it doesn't need timing up... If it's the little one, ask G-man... ;) The silencer outlet is pretty easy to get off... Remove the rubber pipe which connects it to the pipe to the intercooler. Remove the screws which hold the 2 parts together (I think there are screws, it's ages since I did this) Unclip the 2 halves and remove the half furthest from the charger Undo the bolt that's now exposed inside the half on the charger BE VERY CAREFUL NOT TO DROP ANYTHING INTO THE CHARGER!!!! Remove the other half Fit RSR with same bolt, fit connection pipe... Done... 8) Quote Share this post Link to post Share on other sites
Rustynuts 0 Posted May 19, 2005 They are screws that hold the two halves together, however the bottom two are right gits to get to, so could do what i do and take a hammer to the box and break it up to get to the mounting bolt. Quote Share this post Link to post Share on other sites
billinjah 0 Posted May 19, 2005 cmon guys the bits i was referring to was in the subtitle :roll: cheers for the advice henny. i take it the subtitle came up?? Angel eyes oh cheers honey bun! (yes i do now what your refering to!!) Quote Share this post Link to post Share on other sites
joebloggsVR69 0 Posted May 19, 2005 :D The subtitle doesnt show if you've used the view latest posts function (which I'm guessing is what most of us use :wink:) Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted May 20, 2005 you can get the box out whole, :D use a wobble extension bar to undo the 13mm bolt that holds the silencer box on, then when its loose, take off the boost return pipe charger end and take off the top rad cover so you can pull up the top radiatior hose a little and pull up the boost return pipe a little. and then you should be able to extract the silencer box in one piece,, hope that makes sense,,, :roll: Quote Share this post Link to post Share on other sites
billinjah 0 Posted May 20, 2005 payday next week a call to gwerks it is then! Quote Share this post Link to post Share on other sites
