flusted
16v CAI
Ive just had a mate fab me up this airbox outta ally,which will allow me to run a cone filter under the wheel arch.
Its basically a prototype at the mo but he is prepared to make more if people are interested?
Not sure how to go about stoppin filter sucking up water from the road yet,but il proberly make a shield of some sort.
Heres the pic
Still workin on it.Guna get some hooks welded to it so the original rubber bands can still hold it in place,and need to make a right angle on the tube comin out of box as the samco doesnt fit through the hole.
may be better taking the inlet out of the front right hand corner so you can run a large pipe, 80mm or so, down the original carbon canister hole,(not sure if the 16v`s had a canister but if not there will be a plate where the hole is that`ll just tap out with a mallet done this on my golf`s),,, strove motorsport did an induction kit a little similar to this it may be worth you having a search on there for more ideas,
looks like a quality piece of work so far :wink:
It does run down through the carbon canister hole! Stroeves 1 sits in the engine bay lapping up hot air!
