matthewb1985 0 Posted June 29, 2005 there is a small damp patch in my passanger footwell, cant seem to locate where it might be coming from took dash out yesterday and there was nothing any ideas?? also any idea where i can get some rubber roof strips and a passanger window seal form for a good price?? cheers Quote Share this post Link to post Share on other sites
Henny 0 Posted June 29, 2005 http://www.gpcvwaudi.com 8) Give 'em a ring though 'cos their website's naff... Quote Share this post Link to post Share on other sites
matthewb1985 0 Posted June 29, 2005 cheers will do Quote Share this post Link to post Share on other sites
Henny 0 Posted June 29, 2005 oh, and as for the wet patch, is the water greasy at all? That's a sign it's got coolant in it so is probably from either the heater matrix or the pipes to/from it. If not, then check the gromets that go through the bulkhead where all the cables go through and clean out the tray where the windscreen wiper motor lives... They collect leaf debris which clogs up the drain points and makes any rain water find another way to drain... normally into the car... :roll: If none of those are the problem, then there's a couple of other places to look which can be found by using the search... ;) Quote Share this post Link to post Share on other sites
matthewb1985 0 Posted June 29, 2005 no its not greasy just damp my mate just got a vr6 had to tkae whole interior out due to same prob. checked grommets yesterday when putting an amp lead in. il claen the tray out and see if that works cheers Quote Share this post Link to post Share on other sites
daves16v 1 Posted June 29, 2005 Fan inlet duct seal on the scuttle panel. Quote Share this post Link to post Share on other sites
RS VR6 0 Posted June 30, 2005 Water was getting in from the fresh air vent on mine. Quote Share this post Link to post Share on other sites
