steveo29 0 Posted July 3, 2005 okay i got hold of a gunson timing light that has an advance dial l hooked it up , ran the engine until warm, then disconected the blue temp sender..reved past 3k 3 times .then i set the dial to 6 deg and twisted the dist until the tdc marks on the cambelt cover/bottom pulley lined up. is that right ? never used one with dial before, i realise the bottom pulley isnt as accurate as the flywheel Quote Share this post Link to post Share on other sites
h100vw 0 Posted July 3, 2005 Thats right mate. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 3, 2005 Don't you rev it 3 times past 3k to get it out of timing mode? Quote Share this post Link to post Share on other sites
steveo29 0 Posted July 3, 2005 oh..just realised i set the timing while holding the revs around 2k....was that right or wrong didnt seem to alter it anyway Quote Share this post Link to post Share on other sites
h100vw 0 Posted July 4, 2005 Steve disconnecting the BTS stops it from advancing at all. You can do it at tickover or 2k+. The reason you rev it 3 times is to make sure it is not idling up from a cold start. If you notice when the car is cold it ticks over faster. Rev it up 3 times and it settles down to normal. Gavin Quote Share this post Link to post Share on other sites
Tempest 0 Posted July 4, 2005 Yes, you have to rev it to 3x >3000 rpm after reconnecting the BTS as well. Tempest Quote Share this post Link to post Share on other sites
steveo29 0 Posted July 4, 2005 Tempest said: Yes, you have to rev it to 3x >3000 rpm after reconnecting the BTS as well. Tempest well i didnt....i just set the timing, put back the bts and shut off....should that have caused any probs Quote Share this post Link to post Share on other sites
