Shaggy
intake temp gauge?
Does anyone know where i can get a gauge that can measure my intake temps on my corrado G60? or is there a function on the mfa i can use?
Regards
Mike
you can get on from maplins for around £12 they fit nicley just before the throttle body.
just looked on maplin site cant seem to find anything suitable? unless it is not listed on the site???
You could stick the sensor in the inlet. The wires will probably squish down a fair bit but you might need a bit of sealer(not silicone) to make it air tight.
Of course you need to mount the display in the car first and run the sensor through the bulkhead.
Gavin
