steveo29 0 Posted August 3, 2005 my g60 has stated to make a dodgy bearing noise that seems to come from the alt/charger area and is an random short grrrr while the idles if i put a load on the alt, i.e put all the lights on at once the noise appears straight away and goes when i turn off the lights the long screwdriver stethescope doesnt seem to pin point it...does those symtoms sond like a dud alt bearing? Quote Share this post Link to post Share on other sites
stevemac 0 Posted August 3, 2005 Have you tried removing the belt & "feeling" the bearings by turning the pulley with your hand ? Quote Share this post Link to post Share on other sites
steveo29 0 Posted August 3, 2005 no i havent...the noise is intermitant, so im not sure if it will show by hand i will try though :) Quote Share this post Link to post Share on other sites
steveo29 0 Posted August 3, 2005 btw....id like to upgrade to 90A if its worn, any one know a cheap source for a bosch unit Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 3, 2005 steveo29, check the cambelt tensioner!!!! Quote Share this post Link to post Share on other sites
bcstudent 0 Posted August 3, 2005 Like Supercharged said ^^^^ However, if you're sure it's the alternator you'll definitely be able to feel/hear a dodgy bearing by removing the belt and spinning the alternator pulley by hand. Quote Share this post Link to post Share on other sites
steveo29 0 Posted August 3, 2005 it has had a tensioner a while back...similar noise though i wondered/hoped it was the alt beacuse it does it when i load the elec system Quote Share this post Link to post Share on other sites
