G60Dan 0 Posted August 10, 2005 A mate has a 2.0 16v C. She's seems to be getting really low pressure on the brake pedal! In fact it's taking till the pedal hits the floor before it stops the car, and even then it's braking badly. Pads & disc are fine, fluid is fine. What's she looking at? Servo? Master Cylinder? Cheers Dan 8) Quote Share this post Link to post Share on other sites
davidwort 0 Posted August 10, 2005 A mate has a 2.0 16v C. She's seems to be getting really low pressure on the brake peddle! In fact it's taking till the peddle hits the floor before it stops the car, and even then it's braking badly. Pads & disc are fine, fluid is fine. What's she looking at? Servo? Master Cylinder? Cheers Dan Is the pedal very spongey or does it gradually sink to the floor?, latter is usually master cylinder. David. Quote Share this post Link to post Share on other sites
G60Dan 0 Posted August 10, 2005 yeah that's the one. Is it a big job? Never done it myself. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 15, 2005 Could also be a vac leak... Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 15, 2005 Peddle :lol: The Spellin gits worse on ere everyday dun it... Quote Share this post Link to post Share on other sites
Bally 0 Posted August 15, 2005 lol.. bet you make spelling mistakes too when typing fast kevvvvvvvvvv lol Quote Share this post Link to post Share on other sites
G60Dan 0 Posted August 15, 2005 Could also be a vac leak... Where's the vac leak likely to be do you think? As I said before, I haven't done this myself before, so not sure really where to start looking. Peddle :lol: The Spellin gits worse on ere everyday dun it... The "gits" on here get worse every day too :roll: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 15, 2005 There is a vac pipe that comes out of the brake servo... Quote Share this post Link to post Share on other sites
G60Dan 0 Posted August 15, 2005 Thanks for the help btw, Just looked at mine and see the hose. Thanks, I'll check it out. If it needs a new master cylinder, is it a case of emptying the reservoir, undoing the two main bolts and old one comes out, new one goes in, then obviously bleed the brakes. Cheers Quote Share this post Link to post Share on other sites
davidwort 0 Posted August 19, 2005 up not a great help, but a haynes manual covering the 88-92 passat covers most of what you need including the same ABS system used on Corrados of the same age, I've never actually done a master cylinder myself but it is covered in Haynes. David. Quote Share this post Link to post Share on other sites
