mrbeige 0 Posted August 23, 2005 Just thought I'd let you all know its just taken me 3 fookin hours to take off the offside wishbone! Bloody bottom ball joint was tight as a nuns ...... And its dark now...:( The rear bush on the wishbone is in a right sorry state. The rubber as completely come away from the metal insert! :shock: :shock: Anyone in the Cambridge area want ot give me a hand tomorrow night, finishing it off?? Here's a pic of one of the bushes..... :shock: Quote Share this post Link to post Share on other sites
sciroccotune 0 Posted August 23, 2005 bad luck mate, mine look the same tbh!! :cry: Would help but live in newcastle (BTTT lol) Quote Share this post Link to post Share on other sites
adamukcorrado 0 Posted August 23, 2005 yep and mine, but the more i hear the more likely i am to take mine to a garage! any tips tho in case i do decide to do it myself?? good luck tomorrow! Quote Share this post Link to post Share on other sites
mrbeige 0 Posted August 23, 2005 adamukcorrado said: yep and mine, but the more i hear the more likely i am to take mine to a garage! any tips tho in case i do decide to do it myself?? good luck tomorrow! Yeah, take it to a garage!! :lol: Tips - use plenty of WD40! Make sure you've got a 1/4 drive socket set. Remove the brake calipers and carriers to improve access to the bolt on the bottom ball joint That's as far as I've got. Quote Share this post Link to post Share on other sites
adamukcorrado 0 Posted August 23, 2005 yep, a garage it is then, don't fancy getting half way and not being able to finish the job! forecast says rain tomorrow, not ideal for rollin around under your car! have fun! :) Quote Share this post Link to post Share on other sites
mrbeige 0 Posted August 23, 2005 adamukcorrado said: yep, a garage it is then, don't fancy getting half way and not being able to finish the job! forecast says rain tomorrow, not ideal for rollin around under your car! have fun! :) yeah thanks for reminding me :lol: Quote Share this post Link to post Share on other sites
mrbeige 0 Posted August 24, 2005 Picture added at top... Quote Share this post Link to post Share on other sites
bix 0 Posted August 24, 2005 Quote Bloody bottom ball joint was tight as a nuns ...... Why didnt you just undo the 3 bolts in the wishbone to get the balljoint off? Also how did the front wishbone bolt come out? Quote Share this post Link to post Share on other sites
mrbeige 0 Posted August 24, 2005 The ball joint was knackered too, and I didn't want to pull the driveshaft out! The front wishbone bolt was bloody tight too, required some foot action! Quote Share this post Link to post Share on other sites
mrbeige 0 Posted August 24, 2005 Woohoo...... :D :D :D :D :D :D :D 45mins to fit offside wishbone & ball joint, and 1 hour to remove and fit nearside wishbone & ball joint! Next one should take me 30mins at that rate!! :lol: Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted August 24, 2005 plus gas is better as a realeasing agent than wd40 mate , i know this is probably too late :-( Quote Share this post Link to post Share on other sites
sciroccotune 0 Posted August 24, 2005 I know that this has probable been done but do you fancy a quick 'how to' since i have the same car and i'm betting on the same problem?? :afro: Quote Share this post Link to post Share on other sites
mrbeige 0 Posted August 24, 2005 sciroccotune said: I know that this has probable been done but do you fancy a quick 'how to' since i have the same car and i'm betting on the same problem?? :afro: Quick how to then.... 1. Remove wheel 2. Remove caliper and bottom bolt from caliper carrier, to get easier access to the pinch bolt on the bottom ball joint. 3. Apply WD40 or Plus-gas liberally to front bolt, bottom wishbone bolt, pinch bolt, and antiroll bar drop link nut. Leave for a few minutes, and re-apply throughout the process of undoing them as they will be very tight. 4. Undo all three bolts and drop link nut. Its likely that the drop link will shear off as water settles between the rubber washers. If it doesn't snap, I would change them as a matter of course because you will have appled a torque to the shaft of the bolt and weakened it 5. Push the ball joint end of the wishbone down to drop it out of the hub. You may need to prise apart where the ball joint sits into. 6. Push the front of the wishbone down then pull toward the front of the car. 7. Take the new wishbone and fit the rear in position, which will probably require a few light taps for it to locate in the two semicircular tabs. 8. Locate the front of the wishbone, and put the bolts in place front and rear. 9. Fit the new ball joints, with the metal bracket and three bolts, int o the wishbone, re-position the ball joint so it is in position to be pushed into the bottom of the hub. 10. Apply upward pressure to the ball joint, again this may require a few light taps. You need to look throught the hole where the pinch bolt goes, so you can see how much you need to push it up. Probably best to tap the wishbone, rather than the bottom of the new ball joint. 11. Put the pinch bolt in and tighten 12. Tighten the other two bolts, front and rear, in the wishbone. 13. Refit the antiroll bar drop link, making sure its the right way around, as the loop is offset from centre. 14. Finally refit wheel and off you go!! Parts that I changed per side 1x Wishbones - (can find this one) 1x Ball joints - 357 407 365 1x Ball joint fixing plate - 191 407 175 3x Ball joint fixing bolts - 101 277 06 1x Front wishbone bolt - 904 840 03 Hows that? Not a mechanic, but it might help...:) Quote Share this post Link to post Share on other sites
sciroccotune 0 Posted August 24, 2005 Will indeed help, thanks for that :-) Not gonna be doing this till end of October when I get the courage up lol Quote Share this post Link to post Share on other sites
mrbeige 0 Posted August 24, 2005 The second one was a lot easier, and took me almost a 1/4 of the time to do! Quote Share this post Link to post Share on other sites
adamukcorrado 0 Posted August 25, 2005 cheers for that, may have inspired me to do it myself after all! how much did the parts set you back?? Quote Share this post Link to post Share on other sites
potatonet 0 Posted August 25, 2005 yeah I dropped the subframe to do mine, good luck getting the new bushes in, I had a machine shop do it... mine were virtually non existent tho... Quote Share this post Link to post Share on other sites
mrbeige 0 Posted August 25, 2005 adamukcorrado said: how much did the parts set you back?? £130ish for the wishbones, ball joints, plates and bolts from VW with 10% discount £9.25 each for the drop links from GSF potatonet said: yeah I dropped the subframe to do mine, good luck getting the new bushes in, I had a machine shop do it... mine were virtually non existent tho... I bought the complete wishbones, with the bushes in as they were only £40 each! Quote Share this post Link to post Share on other sites
potatonet 0 Posted August 25, 2005 hahah my bushes were half that Quote Share this post Link to post Share on other sites
Dogzyboy 0 Posted February 5, 2007 Apologies for dragging up an old post, but I'm a bit stumped for ideas. Here's my post on another topic: Whipped off one of the wheels this afternoon to see what is involved in replacing the wishbones. What I did notice is that the front bolt appears to be too close to the sump to remove. Am I being a bit dim here in thinking the sump is going to cause problems with removal? :? Any advice would be very welcome as I've just had an oil change & dont fancy having to remove the sump!! Cheers, Doug Quote Share this post Link to post Share on other sites
herisites 0 Posted February 5, 2007 I was told that you have to remove the sump on a vr to get to the bolt mate and if you do you have to then replace the sump gasket. But i also heard that lowering the sub frame slightly allows you to get access :? when i do mine i am going to just take the sump off replace the gasket and oil etc at the same time so its getting fresh oil and fresh wichbones/bushes :D Quote Share this post Link to post Share on other sites
dinkus 10 Posted February 5, 2007 Vince did my wishbone bushes without the need to take the sump off, so it is possible... no idea how tho :? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 5, 2007 dinkus, you jack the engine... Quote Share this post Link to post Share on other sites
Heardy 0 Posted February 5, 2007 Undo front and rear engine mounts and jack engine up. Dead easy then. I've done a few of these and found that the cross bolt through the wisbone seizes in then you do have problems so Beware. Quote Share this post Link to post Share on other sites
Dogzyboy 0 Posted February 6, 2007 Oh cr@p. There goes my best intentions of DIY then. Either option is a bit beyond me to be honest. I guess I'll just wait until I need an oil change again, and I'll either drop the sump, change to oil & replace the sump gasket all in one go. Or take it to someone competent to go for their preferred option. Thanks for all advice guys. Quote Share this post Link to post Share on other sites
