Blue_Joe 0 Posted September 18, 2005 As many of you know I have taken the engine out of the car to be rebuilt to a better spec and acid dipped to clean it up. I want to then paint the engine block, head, rocker cover, charger and all of the other ancilleries to preferably a gloss black to match the body! What is the best paint to use for this, preferably in a spray can for a smooth finish??? Do I just use the high temp paints from halfords that go up to about 500 deg or are there a better option out there that can withstand the heat and steam/pressure cleaning! That will also last long term?????? You're help will be much appreciated Quote Share this post Link to post Share on other sites
steveo29 0 Posted September 18, 2005 por15 engine paint.... Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted September 18, 2005 I second that stevo29,whilst building up my g60 valver engine i sprayed the rusty exhaust mani. using some high temp. spray paint,utter crap,the(treated) rust came through after a couple of weeks and now looks horrible. Por15's range of products are available through frost automotive products. Quote Share this post Link to post Share on other sites
dinkus 10 Posted September 19, 2005 Scruffythefirst just had all his engine bits painted by a paintshop. They used a 2-pack paint because they said it's be better than powder coat and it was pretty cheap too. No idea how it's going to stand up to heat, cos he's not got as far as finishing the engine build yet, but if you're interested I can find out what they used... Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 19, 2005 Hammerite Smoothrite is fine for this purpose. Used in on my turbo 16V to good effect. Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted September 19, 2005 I was told Hammerite Smoothrite wasn;t heat resistant enough! Quote Share this post Link to post Share on other sites
Scruffythefirst 0 Posted September 19, 2005 Scruffythefirst just had all his engine bits painted by a paintshop. They used a 2-pack paint because they said it's be better than powder coat and it was pretty cheap too. I had some very visible bits done in 2 pack and laquered cos the powdercoating place thought they'd get a better finish and a better choice of colours. My blocks done in hammerite, and i've got some stuff powdercoated in gloss black. Although if it did it again, i'd get everything done in 2 pac and laquered and all the brackets and stuff powdercoated. probably cost you less than £100 for 2 pac for the whole eningine and powdercoating. Quote Share this post Link to post Share on other sites
StormchargedVR6 0 Posted September 21, 2005 If you do want to get it Powder coated try http://www.aerocoat.net been told there very good :) Quote Share this post Link to post Share on other sites
Henny 0 Posted September 22, 2005 Hammerite is oil based, so if you EVER spill any oil or petrol in the engine bay, or work on the engine with greasy hands, it'll take the paint off the engine... :| Alloy wheel paint is good, although that's normally silver. void the "ultra high temp" paint sprays (with a 4 branch manifold on the spray can) 'cos they're crap as VEEDUBBED, says... I used the hi-temp paint on engine laquer, which, as the name implies, is designed for painting onto engines! :lol: It's a brush on paint, but you can get a VERY good finish with it as it's nice and thick and takes ages to set so it sags neatly into a nice coat rather than leaving brushmarks everywhere... It's oil and temp resistant but it does smell horrible for the first couple of minutes after you first warm the engine up... :pukeright: :lol: Quote Share this post Link to post Share on other sites
_leon_ 0 Posted March 7, 2006 i'm just getting the rocker cover powdercoated. It should be fine.... Quote Share this post Link to post Share on other sites
VRTrickster 0 Posted March 7, 2006 The rocker cover would not have to be painted in high temp paint ? As I would like to do mine at some stage? Quote Share this post Link to post Share on other sites
_leon_ 0 Posted March 7, 2006 it shouldnt ever get that hot up there - but beadblasting and powdercoating it is adequate afaik. Mine is costing £30. Quote Share this post Link to post Share on other sites
ardandy 0 Posted May 10, 2006 Does it have to be special paint thats only in base colours or can you get it done in say body colour? Metallic? Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted May 10, 2006 In the end, paint just wasn't up to the job........ It was fine with the heat, but just kept chipping off with the slightest knock with a spanner or something. I also found out after it cost me as much to paint as it does to powdercoat, so I have now gone to powdercoating everything I want done Quote Share this post Link to post Share on other sites
ardandy 0 Posted May 10, 2006 Are you not limited with colours for powder coating though? Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted June 20, 2006 back to ard andys answer are you not limited to certain colours when powder coating? Quote Share this post Link to post Share on other sites
A20 LEE 0 Posted June 20, 2006 http://www.frost.co.uk you'll find what you need here. Quote Share this post Link to post Share on other sites
Henny 0 Posted June 21, 2006 a decent powdercoater will have a very broad range of colours including mettalics... I use Greenspeed in Macclesfield - they're reasonable pricewise and excellent service and quality wise... The engine mounts I had done 3 years ago still clean up to be mint now, and that' after they've been ripped out of one car and plonked into another too! :lol: Quote Share this post Link to post Share on other sites
_leon_ 0 Posted October 24, 2006 my powdercoat finish is pretty durable - gets dirty and knocked here and there - no marks etc Quote Share this post Link to post Share on other sites
