bix 0 Posted September 22, 2005 Just got this done, quite happy with that :) Quote Share this post Link to post Share on other sites
chrishill 0 Posted September 22, 2005 impressive figures! how do you say your surname though MR (long black oblong box)? Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted September 22, 2005 looks good whats the spec of your car? Quote Share this post Link to post Share on other sites
Henny 0 Posted September 22, 2005 Nice... what mods have you done? That dip at 5500rpm looks like it could do with sorting though... I think this is normally the sign that the hall sender's not 100% happy... :? Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted September 22, 2005 or sns chip making the car go really rich as the stock injectors go static? Quote Share this post Link to post Share on other sites
bix 0 Posted September 22, 2005 Spec: l&s cartec rsr charger(not great I think), 68mm pulley, red tops, schrick 268/276, sns s5 chip(could do with mapping i think), golf fmic, k&n panel filter, milltek. Think the plugs and lead are past there best, but dunno if this would cause the dip? Would have put the 65mm pulley on if I was planning on getting a power run done, but I only went to get wheel alignment done, couldnt resist the dyno :) steering is soo much smoother now and it goes in a str8 line :-P Quote Share this post Link to post Share on other sites
Ronan 0 Posted September 22, 2005 What am i missing? In the owners manual it says G's are 225lb/ft as standard!! Looks good tho, nice power curve. Quote Share this post Link to post Share on other sites
steveo29 0 Posted September 22, 2005 mine had a big ol dull spot around 5k...seems the chip was way rich there Quote Share this post Link to post Share on other sites
bix 0 Posted September 22, 2005 What am i missing? In the owners manual it says G's are 225lb/ft as standard!! Looks good tho, nice power curve. I think you'll find thats Nm (newton(100g) meters), which aint lb/ft Quote Share this post Link to post Share on other sites
Riley 0 Posted September 22, 2005 nice 8) can you actually have the chips mapped then? tweaked? :? Quote Share this post Link to post Share on other sites
W3RKD 0 Posted September 22, 2005 not a bad result.. did you happen to get an afr plot also ? Quote Share this post Link to post Share on other sites
bix 0 Posted September 22, 2005 not a bad result.. did you happen to get an afr plot also ? No unfortunately :( Quote Share this post Link to post Share on other sites
bix 0 Posted September 22, 2005 nice 8) can you actually have the chips mapped then? tweaked? :? Yeah, I dunno where tho? Quote Share this post Link to post Share on other sites
Riley 0 Posted September 22, 2005 nice 8) can you actually have the chips mapped then? tweaked? :? Yeah, I dunno where tho? mmmm,so the sns can be tweaked to suit the individual application then? darren? do you have the facilitys to do this? neil. Quote Share this post Link to post Share on other sites
bix 0 Posted September 22, 2005 Yup you can get a custom mapped sns stage 5 chip :) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 22, 2005 Nice curves mate, a good, healthy engine 8) Quote Share this post Link to post Share on other sites
bix 0 Posted September 22, 2005 Cheers 8) I think the dip around 5.5k is where the supercharger belt starts slipping :| Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 22, 2005 Slippage never a good thing.... how's your dizzy? I hear a worn one can cause a power dip at 5500rpm, Henny and GMan/Pitstop will know more on that.... Quote Share this post Link to post Share on other sites
bix 0 Posted September 22, 2005 Yeah having said that, you can hear the belt slip at about 4.7k, but looking on the mfa I think the boost did drop off a bit around 5-5.5k so thats prolly what it is. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 22, 2005 Is there any way of tightening the belt? You mean the serpentine, or the internal one? Sorry, my G Lader knowledge is limited... but I have read on a few occasions about an unexplained power cut at 5500rpm being caused by a worn distributor. Not saying that's your problem for sure, but it's worth looking at :-) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 22, 2005 Shorter belt for a smaller pulley, also check the state of the tensioning strut. Quote Share this post Link to post Share on other sites
bix 0 Posted September 22, 2005 Yeah I have a smaller belt, tensioner is ok too, even tried packing the spring down a bit, didnt seem to make a lot of difference :| Quote Share this post Link to post Share on other sites
bix 0 Posted September 22, 2005 Yeah the serpentine belt, be in trouble if the internal on slipped :? Quote Share this post Link to post Share on other sites
Riley 0 Posted September 22, 2005 just looking at the plot again,does it produce power right upto 6300ish? rpm? is that not really good going for a g? mines flat as a fart after 5k :? but the dizzy bussiness sounds a possability... Quote Share this post Link to post Share on other sites
NickVR6 0 Posted September 22, 2005 Nice figures mate. The torque figures from the Gs allways make me wonder whether i should have bought one instead of the vr, that eternal question! When the noise tingle dies i'll prob think a bit more! Will henny get his RR'd, i'd love to see the figures on that puppy? Quote Share this post Link to post Share on other sites
