g60rado 0 Posted August 5, 2003 Will a cluster from a 2.0L 16v Passat fit the g60. The clocks look the exact same, but i'm not sure how they hook up. I'm looking to replace my clocks and cant find one out of a g60. Quote Share this post Link to post Share on other sites
W3RKD 0 Posted August 5, 2003 i have some for sale if you are intrested it would only cost another £17 to get them to you... :lol: Quote Share this post Link to post Share on other sites
g60rado 0 Posted August 5, 2003 do you have the g60 ones, or the ones from the passat? I'm just trying to see if the one if found will fit. Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted August 5, 2003 from what ive seen/heard the passat clocks do fit Quote Share this post Link to post Share on other sites
glen`s 16v 0 Posted August 5, 2003 yip passat clocks are the same but check the top speed and R.P.M are the same as some passats are slower :D Quote Share this post Link to post Share on other sites
G60Jet 1 Posted August 5, 2003 i think you will need passet G60 clocks as the clocks are are different inside from what niko (i think) said Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted August 5, 2003 Passet G60? Wassat? Quote Share this post Link to post Share on other sites
G60Jet 1 Posted August 5, 2003 lol oaps i mean passat G60 Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted August 5, 2003 didnt even know the made a passat g60 Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted August 5, 2003 lol oaps i mean passat G60 OAPs? Quote Share this post Link to post Share on other sites
Dboy 0 Posted August 5, 2003 yep, i have seen a passat G60 - didnt know if it was just the badge stuck on, it was parked up so never looked under the bonnet, but i have seen a passat G60 Quote Share this post Link to post Share on other sites
g60rado 0 Posted August 5, 2003 well, here's how they look: Quote Share this post Link to post Share on other sites
W3RKD 0 Posted August 5, 2003 have you got a pic of the rear of the clocks please ? Quote Share this post Link to post Share on other sites
stevemac 0 Posted August 5, 2003 didnt even know the made a passat g60 I can confirm - Passat G60's (think they were 4wd but I maybe wrong) do actually exist. Not sure if they were ever imported into the UK though. Speedo in Corrado G60 is 160mph - Passat G60 is 140mph Not sure if it will physically fit the dash & electrics though Quote Share this post Link to post Share on other sites
stevemac 0 Posted August 5, 2003 g60rado - I see your from the states. Passat G60's were definitely exported to the states. Is your Corrado G60 speedo 160mph like in the UK ?? Quote Share this post Link to post Share on other sites
g60rado 0 Posted August 5, 2003 the g60 in the states, or atleast all of the ones i have seen, have speedos of 140. Quote Share this post Link to post Share on other sites
stevemac 0 Posted August 5, 2003 the g60 in the states, or atleast all of the ones i have seen, have speedos of 140. Must be due to emissions regulations.... :( Quote Share this post Link to post Share on other sites
g60rado 0 Posted August 6, 2003 i know, it sucks, but who uses the speedo anyway :twisted: anyway, iall the numbers are the same, im just wondering about the harness and because of the boost readings. It says it fits a 90-93 passat. Quote Share this post Link to post Share on other sites
g60rado 0 Posted August 9, 2003 so, does anyone know if it will fit? I might just give it a go, and see what happens! Quote Share this post Link to post Share on other sites
dubster82 0 Posted August 9, 2003 I persume it depends on wether or not it has a Vacuum pug on it. Quote Share this post Link to post Share on other sites
stevemac 0 Posted August 9, 2003 i know, it sucks, but who uses the speedo anyway :twisted: anyway, iall the numbers are the same, im just wondering about the harness and because of the boost readings. It says it fits a 90-93 passat. If the part numbers are the same then you shouldn't have a problem. I'd just bung it on and see what happens... :wink: Quote Share this post Link to post Share on other sites
g60rado 0 Posted August 10, 2003 worst comes to worst, i just wont have a boost reading on my mfa if there is no vacuum plug, right? Quote Share this post Link to post Share on other sites
dubster82 0 Posted August 10, 2003 mmmmm, not sure, i think i was told when my boost gauge was installed that if it ever went wrong,(leak) the car wouldn't run right. But they might be different way of reading the boost ? Quote Share this post Link to post Share on other sites
stevemac 0 Posted August 11, 2003 worst comes to worst, i just wont have a boost reading on my mfa if there is no vacuum plug, right? I think you may have to seal the pipe but you should be okay. Try detatching & sealing the pipe with your existing set of clocks still installed. If the car still runs okay then you won't have a problem. Quote Share this post Link to post Share on other sites
trev-b 0 Posted October 10, 2005 Theres a Passat GT in my local scrap yard with a speedo that goes to 160mph. May be clocks from a C G60? Think i'll go and pick them up tmow. Quote Share this post Link to post Share on other sites
