Greenbat 0 Posted October 22, 2005 I recently had my charger refurbished to a stage 4 by Jabba Sport. A jabba sport chip was fitted at the time. Since the refurbishment, anytime I hit about 5000 revs the power drops dramatically and then picks up again ABOUT 6100. I have attached my power runs. I can only describe it as similar to a turbo lag Has anyone experience this before. Help Greenbat Quote Share this post Link to post Share on other sites
JT 0 Posted October 22, 2005 have you just had a stg 4 and chip or a 68mm pulley put on too :?: Quote Share this post Link to post Share on other sites
stevemac 0 Posted October 22, 2005 Mine had similar symptoms a coupe of years ago. Did Jabba check that ALL of the other sensors were working properly before they mapped it ? If not (it's very possible they didn't) - it could be that one of your sensors is knackered. Just out of interest - what spark plugs are fitted ? Quote Share this post Link to post Share on other sites
Greenbat 0 Posted October 22, 2005 Had a stage 4, 68mm pulley and chip. This is where is get complicated because the charger was fitted by Dubsport and the chip and pulley by Awesome. Stevemac which sensoprs ned to be checked? Greenbat Quote Share this post Link to post Share on other sites
stevemac 0 Posted October 22, 2005 AFAIK - VERY similar problem was discussed on here a couple of years ago. From memory, weak hall sender was the culprit. Contact g-man on here & he may be able to confirm. Quote Share this post Link to post Share on other sites
W3RKD 0 Posted October 22, 2005 i cant see the attachment unfortunatly Quote Share this post Link to post Share on other sites
stevemac 0 Posted October 22, 2005 You have "Adobe Acrobat" reader Daz ? If not - you'll need to install this first - http://www.adobe.co.uk/products/acrobat/readstep2.html Quote Share this post Link to post Share on other sites
W3RKD 0 Posted October 22, 2005 i can read pdf files fine just not this one... odd Quote Share this post Link to post Share on other sites
Furkz 0 Posted October 22, 2005 its coz u got a test version or something :lol: Quote Share this post Link to post Share on other sites
W3RKD 0 Posted October 22, 2005 cheers furki.. i can see it now. you dont by chance have a AFR Plot also do you ... Quote Share this post Link to post Share on other sites
billinjah 0 Posted October 22, 2005 mine does that i think its belt slippage? Quote Share this post Link to post Share on other sites
stevemac 0 Posted October 22, 2005 mine does that i think its belt slippage?Possible but the power picks-up again at higher revs Quote Share this post Link to post Share on other sites
billinjah 0 Posted October 23, 2005 yeah mine too Quote Share this post Link to post Share on other sites
Greenbat 0 Posted October 23, 2005 Cheers Guys, as Stevemac advised, I went through some old threads last nite and I came across this one "The infamous 5k Flatspot!!" Link is http://the-corrado.net/.archive/forum/viewtopic. ... sc&start=0. I suspect the culprits could be the hall sender and the dizzy. I have ruled out the belt because it is a new one and also the power returns at higher revs. I will look for 2nd hand ones and try them out. Will put a a post in the wanted section but if anyone got one please send me a PM. Cheers Greenbat Quote Share this post Link to post Share on other sites
stevemac 0 Posted October 23, 2005 Greenbat, Hall sender is part of the distributor & not available seperately on G60's. If you need a new one, we (GSF) sell genuine Bosch ones. Beware of using a secondhand one - could be just as worn as the one that you already have. Quote Share this post Link to post Share on other sites
Greenbat 0 Posted October 23, 2005 how much are new ones about £90? Quote Share this post Link to post Share on other sites
stevemac 0 Posted October 23, 2005 Can't remember exactly but that sounds about right. Quote Share this post Link to post Share on other sites
steveo29 0 Posted October 23, 2005 new ones are around the £100 mark i was also told to get a new dist when mine had a flat spot, i got one and no change...in the end i brought a wideband kit and discovered it was very rich in the top end Quote Share this post Link to post Share on other sites
Greenbat 0 Posted October 23, 2005 What is a wideband kit? Mine is also very rich at the top end. CO level were in excess of 10% where it should have been 4% or so. Did the wideband kit cure the flat spot? Greenbat Quote Share this post Link to post Share on other sites
bix 0 Posted October 23, 2005 Id imagine it would have needed to be remapped to cure the rich flat spot, wideband kit just gives you an accurate afr reading! Quote Share this post Link to post Share on other sites
stevemac 0 Posted October 23, 2005 To a certain extent, the car will run rich at Wide Open Throttle (WOT). Microswitch on the throttle housing sends a signal to the ECU. ECU then ignores some of the sensors & richens the fuel mixture in accordance with the mapped chip, within the ECU. Hence the importance of having the car "re-mapped" when alterations are done to the engine setup. Quote Share this post Link to post Share on other sites
