Greenbat 0 Posted November 6, 2005 Hello Guys, my mk2 G60 has got fully adjustable FK Konigsport Coilovers (koni internals). The ride is way too hard. When I bought it I was given a control key for firming and softening the dampers. It is now on the softest setting but still the ride is still way too hard. Can I do anything else to soften the ride? Cheers Greenbat Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 6, 2005 Make them higher? Quote Share this post Link to post Share on other sites
billinjah 0 Posted November 7, 2005 fit higher profile tyres? Quote Share this post Link to post Share on other sites
Furkz 0 Posted November 7, 2005 need to take into consideration that if u make the ride softer the handling "may" suffer also Quote Share this post Link to post Share on other sites
billinjah 0 Posted November 7, 2005 yeah you need to find a happy medium when your driving fast you might not want so much cushion when yer pushing! sorry couldnt resist! Quote Share this post Link to post Share on other sites
Bally 0 Posted November 7, 2005 if the cars low then the ride will be hard... as other say try higher profile tyres or run slighty low tyre pressue lol Quote Share this post Link to post Share on other sites
billinjah 0 Posted November 7, 2005 eat more so you have a fatter arse! Quote Share this post Link to post Share on other sites
Furkz 0 Posted November 7, 2005 eat more so you have a fatter arse! doesnt work :x Quote Share this post Link to post Share on other sites
sambo 0 Posted November 11, 2005 what size wheels and what profile tyres have you got? any bushes beign swapped for poly-s? top mounts not standard? springs of higher poundage than they should be? all of the above could be the culprit i guess.... i have set of konigsports with uprated top mounts and standard wheels,ride soffter and less crashy than standard suspension! Quote Share this post Link to post Share on other sites
logicaltuning 0 Posted November 11, 2005 i had 17s on mine before lowered 60mm - like rock it was then fitted 195/50 15s on standard bbs rims - same drop = smooooooother by miles Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted November 11, 2005 I can vouch for std wheels and tyres, soo much better than the 17s Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 14, 2005 Make them higher? Doesn't always work, I find my H&Rs actually improve the lower I go, but then I start clouting the chin spoiler on things. Quote Share this post Link to post Share on other sites
StuartFZR400 0 Posted November 16, 2005 There are different issues here that can combat your problem. 1. Firstly is the spring. As Sambo mentions, the spring may simply be too hard. i dont know what setup you have, but ideally you would simply back off the spring preload; or for many of us, replace the spring with a softer one. It is the spring that offers most resistance. 2. Not sure which shocks you have; be it gas or oil. Within an oil shock, the oils' movement is restricted by holes in the metal discs within the shock. 2a. On compression (force/push down) the oil is usually free to move, but can be restricted in some shocks - Compression Damping. If yours is adjustable, it is most likely set too hard and can be backed off by unscrewing; although look at your instructions for them. 2b. (not likely to be your problem) The other damping effect that all our shocks have is Rebound Damping; when the shock extends (car rises) the oil is again restricted. I guess on your shocks this can be adjusted. The idea behind this is when you go over a bump or hollow that it prevents silly oscillation; just imagine if there was no shock and only springs - in this case the car would rise after the bump, but then go down, up and down again; often a tell tale sign of buggered normal shocks or not enough Rebound set on the adjustable sorts. http://www.koni.com/_cars/frame.html you can have progressive damping, but lets not go there. Always good to have a fiddle your self and see what you come up with; try different extremes, but... *I guess they are also height adjustable. If you have them set to low and want to keep it low; there is a good change that if you start making things too soft, that you may possibly start to bottom-out, so go a few clicks/screws at a time. In Summary:- I'd say you could back off the Compressive Damping a touch. But at the end of the day, you may just have to live with the hard sporty ride and enjoy your little go-kart!!!! :) This maybe you: Corrado G60 55-85 9,11,15 FKKKVW57 http://fknorthamerica.com/downloads/pdf ... ge_048.pdf Quote Share this post Link to post Share on other sites
