pip
will g60 corrado lowered springs fit a 1.8 16v corrado?
seen some lowered springs etc,but there off a g60 corrado,where as mine is just a standard 1990 1.8 16valver so will they fit my shocks? :?:
if anyone knows for definate please post up asap :wink:
I'd recommend you change the dampers at some stage as the lowering springs wont work aswell on OE shocks..
Yep, if the shocks aren't designed to work at that height they probably won't damp properly and will fail pretty fast too. Properly matched springs and dampers will make for a better ride and good predictable handling.
David.
seen some lowered springs etc,but there off a g60 corrado,where as mine is just a standard 1990 1.8 16valver so will they fit my shocks? Question
if anyone knows for definate please post up asap Wink
If your after some lowering springs i've got a set of 50mm ones which you can have for £40 delivered. 8)
