capnahab
109,500 mile service
right guys my womans got a G reg 16v Rado. It's been regulary serviced and has a nice History section on the book :)
As ive.. well my girlfriend.. has just taken ownership of it, i think its due for a bloody good servicing.
As in more of a MK4 polo guy, could you guys post a sort of list of things that will need doing and what needs buying so I can get it sorted by a mechanic mate.
I aint taking it to VW, as they ripp the P1ss with their prices.
cheers all, and i think this is gonna be a baptism of ph1re into the world of Corrado ownership ££££££££££
well if it was mine i would get the following done(unless there was documented evidence of this being done prior to you buying)
Timing belt(Very important and only use a genuine VW belt),
Oil and Filter change,(genuine VW filter too)
new spark plugs,
new fuel filter,
new air filter,
coolant change.
as above
cam belt tensioner
injector sleeves and o rings(usually cause trouble and cheep to do)
alt voltage reg...restores full power in most cases for £12ish
dist cap & arm
id also advise looking into making heavy duty batt/alt cables and headlight relays..makes a huge differance
cherers for the info guys, I found the sticky as well so im sorted now. Off i go to VW's parts desk with me credit card :shock:
