dannyc 0 Posted December 23, 2005 ayup geezers my c isn't starting :mad: i think it might just be a relay but i thought i'd run it past you lot. when i turn the key all of the igition lights come on and i can hear the feul pump prime but the engine dosen't start. the engine dosen't even get a chance to start. any ideas which relay it will be? cheers :) Quote Share this post Link to post Share on other sites
bix 0 Posted December 23, 2005 Does it not turn over, or just not fire? Quote Share this post Link to post Share on other sites
Henny 0 Posted December 23, 2005 sounds like it could be a dead ignition switch to me... Quote Share this post Link to post Share on other sites
Trig 0 Posted December 23, 2005 Imobiliser?... Quote Share this post Link to post Share on other sites
dannyc 0 Posted December 23, 2005 could be ignition switch cos its not even giving the engine a cheance to start. any idea how much they cost? Quote Share this post Link to post Share on other sites
h100vw 0 Posted December 23, 2005 Is it turning over? or cranking and not firing? Quote Share this post Link to post Share on other sites
Henny 0 Posted December 23, 2005 Just under £25 from VAG... 8) DON'T buy the GSF / ECP cheaper ones 'cos they're crap and will break again... Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 23, 2005 £18 from the dealer... See if your getting 12V's to the the starter soleniod plug when the switch is turned to position 3... Quote Share this post Link to post Share on other sites
dannyc 0 Posted December 23, 2005 thanks for the help guys i'll let you know when i sort it. cheers Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted December 23, 2005 Sounds like a dodgy ignition switch. Quote Share this post Link to post Share on other sites
g60griff 0 Posted December 26, 2005 saw something a while back on here somewhere about a thing you can make out of some wire and connectors that you plug into the plug at the back of the ignition switch and it sort of hotwires the car. do a search and try and find a link that would be an idea then you would find out if its the switch or not. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 26, 2005 Yeah that was me, lol Search for Ignition and Bypass Quote Share this post Link to post Share on other sites
g60griff 0 Posted December 26, 2005 i think il make one of those looms, will come in handy one day, probably Quote Share this post Link to post Share on other sites
