B DUB 0 Posted January 15, 2006 hi ive got a corrado g60 and have recently changed the fusebox .which was in fine working order but now the car has started dieing out when i get to high revs in 3rd gear and as soon as i put it in5th gear . changed the leads /plugs / and dizzy cap which were suggested but still the same . CAN ANYBODY HELP PLEASE ? Quote Share this post Link to post Share on other sites
vr6storm 0 Posted January 15, 2006 sounds like something you've changed is loose Quote Share this post Link to post Share on other sites
selbekk 0 Posted January 15, 2006 have you checked all the connections and fuses if they work? Quote Share this post Link to post Share on other sites
W3RKD 0 Posted January 15, 2006 Does it actually stall or just feel like its being held back ? Quote Share this post Link to post Share on other sites
Walesy 0 Posted January 15, 2006 Maybe the gearstick is hitting a wire or something when moved into 3rd/5th? Quote Share this post Link to post Share on other sites
B DUB 0 Posted January 19, 2006 checked all connectons and are all fine. like i say was going ok for a while aftr i fited the box in then allof a sudden it cuts out and also set of the blimey alarm when i get into high trevs in 3rd gear and as sonn as i put my foot on the excellerrator in 5th . Quote Share this post Link to post Share on other sites
B DUB 0 Posted January 19, 2006 what do u mean by the gear stick hitting the wires WALESY .I f u can explain as a aint a clue .is it something i can do or is it a garage job??? cheers. Quote Share this post Link to post Share on other sites
steveo29 0 Posted January 23, 2006 if it only does it when you change gear then the gerastick or linkage is tugging on some wires Quote Share this post Link to post Share on other sites
B DUB 0 Posted March 15, 2006 this will sound stupid but where shall i look ? under the car?under the bonnet ? or dismantle the housing un the car around the gear stick ??? sos lads i aint a clue what to look for Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted March 15, 2006 B dub i think you'd be better taking it down to darren! he's the G expert amongst! us if you look further up this thread his name is g-man and his address & phone number are on there just give himn a ring his site is http://www.g-werks.com his name is Darren Cheers Andy Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted March 15, 2006 Did you touch anything else when you replaced the fusebox or since you replaced the fusebox? anything you have fitted, replaced anything unrelated? Jay Quote Share this post Link to post Share on other sites
B DUB 0 Posted March 16, 2006 sorted now mate it was the gear linkage hitting a live wire and cutting the engine out ...cheers anyway. Quote Share this post Link to post Share on other sites
