-Neil-
fuel presure problems, one way valve?
i have got terrible starting problems with my 9a 2ltr 16v.
I have done the test of switching on the ignition on and off 4-5 times before starting and this has improved it as i believe this builds up the fuel pressure it loses while the car is stood still.
Can anyone let me know where i would find this one way valve or something related to it?
Many Thanks,
Neil
It's fitted to the outlet of the main fuel pump (under the car). It's only about £15 and it's not hard to change if you don't mind having petrol running down your arm!
Apparently so. I changed mine a few weeks ago while I was down there changing the fuel filter. It was more of a precautionary measure really as it's not the nicest area of the car to be working.
It's not necessarily the non-return valve that's causing the problem though. System pressure can be lost via a number of components.
Are your starting problems from hot or cold?
all from cold. BUT more noticible from when i,
Drive 2 minutes (literally, im lazy) to work, park on a slight backwards hill so the car is leaning backwards a bit, leave it for 4 hours, then start the car, it really struggles to start!
My 1.8 16v used to be exactly the same and when it did eventually start it'd run on two or three cylinders for a few seconds. After two years of that I went through the entire fuel system and cleaned/checked the components one-by-one. In the end I changed the fuel filter, the pump non-return valve and the injectors. It starts and runs perfectly now (as perfectly as you'd expect from such a basic system at least).
Stripping and cleaning the fuel metering head made a marked improvement too. The car used to idle at 1400rpm if driven at a reasonably high speed for any length of time. That doesn't happen now either.
