Rob_B
duff G60
bit of an intermittant one really, sometimes the car will start sweet as, but sometimes, like this morning, it would fire once then die. after this it wont even try to fire, will just turn over with a flat sound. in ignition, the isv makes a very loud buzzing and this dissappears when you disconnect the blue temp sensor. ive tried changing the blue temp sensor and swapping the plug over to the black one, but no joy.
what voltage should there be at the plug for the blue temp sensor?
what is the resistance across the ISV when its disconnected?
this is a stupid little problem, especially after my rebuild, but it means the car wont start all the time which is just as bad!!
when it get going its good as gold!!
cheers Rob
ive put a new one in there, and still no joy. will try another in hope of it being a duff sensor. although im thinking it could be the cabling
stupid intermittant faults!
Rob
20°C: 2500 Ohm
30°C: 1500 Ohm
40°C: 1000 Ohm
50 °C: 800 Ohm
60°C: 600 Ohm
70°C: 400 Ohm
80°C: 300 Ohm
90°C: 250 Ohm
100°C: 200 Ohm
Between 2 and 10 Ohms
If you suspect the ISV doesn't let in enough air during start-up, you could try and wedge open the throttle such that the idle switch is still closed, and see whether that makes any difference.
Possibly time to ring through all the wires in the loom to the ECU :roll:
Tempest
top man. got it going last night but im not convinced ive found a definitive problem yet. will have a good look today
Rob
ok, changed the ISV, blue temp sensor and starter motor today and still no result!
when i turn the engine over it just makes a flat tone with no attempt to fire. i know i have spark and fuel.
i need to know what voltage is sent to the blue temp sensor, i get 5V to ground on the feed and 5V across the 2 pins when the ignition is on.
im really miffed now and if i had any hair i would be pulling out!!
someone please help me!!
Rob
if you think the starter sounds a bit flat..try getting some fatter earth and power leads for the batt/alt/starter...made a nice differance to mine
probably worth adding a extra earth here n there too as what the factory is only just enough
