iow_corrado_g60
found the leak with pics? any ideas?
hi lads first chance to have a good look at my coolant leak not losing a shed load of water but enought its coming from the just near the pas belt any ideas heres the pics
you can see the pas belt and sump!
Anyone know where its coming from?
thanks Andy
definately looks like the water pump mate! thats a very similar leak that i had a while back, a new pump will sort that problem out!
You might wanna think about gettin a new sump on there too man, looks like your one has seen better days
i had a leak similar to that until yesterday. was the thermostat housing, apparntly made out of recycled bumper plastic :S
If you're getting a new water pump to fit your self, buy VAG. I bought the g s f for the Golf and was one tatty peice of work, nasty rough edges etc. Im sure you know to ensure all surfaces are clean when putting back together and use a new seal
I've just found the leak on mine - looks like the thermostat housing. Any ideas on how much these are? GSF don't do them apparently, so i'm assuming main dealer only?
Definatly, especially as they may offer an 'exchange' which they do for the 9a so is only around £30 IIRC.
I'm hoping to change mine this weekend. Has anyone done it before, looks a bit of a bastard to get to! My local veedub specialist is getting one in for me, but I still don't know how much they are. Any ideas?
what for sorry mate thermo housing or water pump?
Thermostat Housing. For a VR if that makes a differences. Can't seem to get a price on them.
id only use a vag pump. i put a new pump on the G60 a while back. i bought it from a gsf type place and im sure it isn't as efficient as the vag one. maybe a different impeller.
only a tenner more so go vag.
