VRTrickster 0 Posted April 7, 2006 Thinking of replacing my tired fuel pump with an uprated aftermarket type. Has anyone fitted one and was there any improvements i.e trottle response ,more top end power etc? These dont actually cost much more than an oe one from the stealers! I was thinking of getting a (Sytec) pump,anyone heard about of or fitted one of these? Quote Share this post Link to post Share on other sites
Trig 0 Posted April 7, 2006 TBH You're better sticking with standard. It provides more than enough pressure (4bar rings a bell) and can sustain it for long periods. A more powerful pump could cause a rich mixture. Quote Share this post Link to post Share on other sites
double-6s 0 Posted April 7, 2006 yeah you're only gonna need an uprated pump if you charge/use bigger injectors surely?? Quote Share this post Link to post Share on other sites
Rossco 0 Posted April 7, 2006 An uprated pump wouldnt cause a rich mixture, your fuel pressure regulator takes care of that Quote Share this post Link to post Share on other sites
flusted 0 Posted April 7, 2006 k-jet pumps can pump 12bar which is wot the lines are restricted to before they burst Quote Share this post Link to post Share on other sites
h100vw 0 Posted April 7, 2006 How much power does kevhaywire do on his supercharged vr? Certainly won't need one on a std car. Gavin Quote Share this post Link to post Share on other sites
Rossco 0 Posted April 7, 2006 12 bar??? Thats 174psi man, where did you get that from??? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 7, 2006 Kev is running an uprated pump but standard ones are fine for NA use, VSR etc.. as with most aftermarket stuff they don't fit as well as the original so stick with OE if you can, less than a ton new... Quote Share this post Link to post Share on other sites
VRTrickster 0 Posted April 7, 2006 Doesnt it come down to flow rates etc? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 8, 2006 I used a Walbro pump to begin with but it sits too high in the pump housing, so the last big white marker on the fuel guage is your lot (about 1/4). I then stuck a Sytec one in and Vince has some special alloy rings to make them sit in the housing tightly and it also sits in the same position as stock (about 5mm off the tank floor) so can use the full range of tank capacity. An uprated pump won't cause any harm on a standard engine as the FPR returns the unused fuel back to the tank as Rosco said, but the Walbro and Sytec can sit at max flow rate and pressure (higher than standard) all day long, the standard can't, especially not when the larger injectors demand a sudden peak of fuel at WOT when running forced induction. The standard pump can cope to a point but it won't last half as long. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted April 8, 2006 How much are these Sytec pumps Kev? Are they a straight fit in? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 8, 2006 About £85 ish I think. Yep, a straight fit but you need one of the locating rings from Stealth to ensure the top of the pump sits tightly in the pump housing, otherwise it'll flop about. When I was running the standard pump, about an hour after a hard thrape I took the pump out (as you do!) and it was very hot, definitely over worked. An uprated pump won't give you more power, but it will ensure the engine delivers maximum power all of the time, plus the uprated pumps are well over engineered and will last indefinitely. Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted April 8, 2006 time for this pic again! SX performance, THE name in fuel pumps. As used on a certain 600bhp hyabusa turbo. That setup there will deliver enough fuel to supply a 750bhp engine. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 8, 2006 That's a monster setup! Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted April 8, 2006 yup! you REALLY don't want to be running lean with a high boost setup, piston melting time. Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted April 8, 2006 I'll actually get around to fitting it one day a bit of an overkill unless you plan on going for 400bhp+ (which I am) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 8, 2006 The pump for the housing looks great, looks like it sits in the standard pick up point which believe me, is a bloody good thing. I was forever running dry with the Walbro, which sits too high. Is the other one an external pump or a filter? Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted April 8, 2006 no, you got it the wrong way round. that's the filter on the tank cap, the bog bit is the pump (bloody heavy it is to, it's like a sodding starter motor!). I can't use the housing though, syncro tank, it doesn't have the locking collar i the bottom of the tank to clip it to, and all my atttempts at making one stick have failed. ack to the drawing board on that one. fuel lines are the same size as my oil filter hoses! Quote Share this post Link to post Share on other sites
VRTrickster 0 Posted April 8, 2006 Where did you buy your sytec pump from kev ? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 8, 2006 I'm guessing Stealth... Quote Share this post Link to post Share on other sites
LowG 0 Posted April 8, 2006 For mild forced induction performance a walbro inline pump would be ok. For more power Aeromotive has the A1000 unit (800hp), you really want a surge tank with this beast. The walbros inline can be bit noisy. Quote Share this post Link to post Share on other sites
buttles 0 Posted August 28, 2006 Just fitting a Walbro pump from Stealth. The adaptor ring does make it sit high as Kev says. I have put a short length of pipe on the inlet to take the opening down to the same level as Std. Anybody see a problem with that?! Ta. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted August 28, 2006 Or be a cheap bastid like me and fit an old K-jet bosch pump sourced from a breaker and fit that,it'll keep up with the output up to 500+brake,costs virtually nowt but has the same problem Kev mentioned,you have to have at least a third of a tank of fuel otherwise it sucks in air whilst cornering but who ever goes racing with their car in reserve?.. Quote Share this post Link to post Share on other sites
