mr.brown 0 Posted April 7, 2006 Do G60s have a dipstick with a flat blade-like profile or a round one? And is the breather (press. reg. valve) always flat or did earlier cars come with a mk2 Golf style round one? Grateful for any assisitance. Quote Share this post Link to post Share on other sites
W3RKD 0 Posted April 7, 2006 Yes the dipsticks the flat 88- style. And the corrados/golfs had the square breather and the rallyes had the round one. Quote Share this post Link to post Share on other sites
mr.brown 0 Posted April 7, 2006 Cheers Darren. Looks like I have a dodgy dipstick tube then. I have the flat style dipstick but it won't go through. It doesn;t seem like there's a blockage - if I blow down the dipstick tube, air comes out the breather hole (engine is in garage btw). How easy is it to replace the whole tube? Quote Share this post Link to post Share on other sites
W3RKD 0 Posted April 7, 2006 The tubes just press in . Not very hard to change at all Quote Share this post Link to post Share on other sites
Henny 0 Posted April 7, 2006 mr.brown, the plastic bit on the top just pulls off, but it will probably break and need some careful surgery to remove it from the dip-stick tube. The metal part of the tube is a push fit (pushed HARD!) into the block... you should be able to pull it out if you can get a good enough grip on it without damaging it... 8) Oh, and some of the very early euro corrados also had the round breather... Kongo's one did... 8) Quote Share this post Link to post Share on other sites
Tempest 0 Posted April 7, 2006 Oh, and some of the very early euro corrados also had the round breather... K As do the 1990 US-spec G60s like mine :-) Tempest Quote Share this post Link to post Share on other sites
