sciroccotune
ignition timing and mixture on 2l16v
Hello chaps,
I just want to check this on my 2l16v. I have recently changed the Cam belt which I think was slightly out, and I’m guessing that the ignition timing may be slightly retarded so I would like to check. (the car is sunning fine and gives around 30mpg so its probs fine but just want to check)
I can’t really find the specific procedure for a 2l (9a), Is it the same as the 16v?
Also how do you set the mixture (CO) settings. I take it you can connect an ammeter on the black plug at the side of the metering head and adjust the CO screw to a specific value?
Cheers
ok i have checked all the haynes books abut none of them cover the 16v engine
Sure they do. The 9A engine is covered in the May 1998 -> 1991 VW Passat manual (ISBN 1 85010 647 9). I'll have a look for my copy.
I was hoping you may know something about this mate :-)
Well all the ones that are currently published don’t seem to have the 9a and the library did not have that one, only 1988-1996.
if you could get some info for me that would be great!!
cheers :D
I've found the manual but I don't have the time to copy out the info at the moment as I'm off out in ten seconds. It may be quicker to rig up the ol' scanner and get you the info that way. I'll do my best to get it done around tea time (unless another helpful sole comes along in the mean time).
I found this on another site
Before doing anything, you need to check all your intake boots, and hoses, and vacuum lines for cracks, tears, or anything that could cause a vacuum leak, since this will affect your fuel mixture reading. If your injector 0-rings are bad, replace them.
You will need a multimeter that can read milliamps, and a long 3mm allen wrench. Turn to the fuel section of the Bentley. Page 54 gives a brief explanation of the procedure, and pages 73-74 have the adjusting values. First thing you want to do is to hook up you multimeter inline with the wires going to the differential pressure regulator (DPR). The DPR is on the fuel distributor, on the side facing the engine, NOT the side facing the right fender. It has a two wire connector going to it. There are many ways to go about wiring this up. You can either get the factory test harness (which makes things a lot easier), VW special tool # VW 1315A/1 (order # TV1 315 0A1 25 ZEL), or you can put wire taps in the wires to the connectors, or you can make your own harness, using 02 sensor type connecors. If it's all hooked up, and you start the car, and it's running rough, and the meter is pinned at zero, you probably have the wires switched. Change them around and try again. If you are using an analogue meter, set it to the 10mA or 25mA scale. When you check your mixture, your car should be at normal running temperature.
That was the "hard" part. Now that everything is hooked up, start your car. After just starting the car, your meter will read a constant 8 or 9 mA. Let it sit for a minute, and the reading will start to fluctuate. THIS IS NORMAL. The reading should be bouncing back and forth consistently. The range of operation is 1-12 milliamps. The reading shouln't be below 1mA, and never above 12mA (if you want your car to run right, at least). The reading should only fluctuate about 2-3 milliamps, for example, the stock setting for a 1.8 16V is 5mA. This means the meter should be jumping between approximately 4 and 6mA, averaging 5mA.
Next thing to remember: the higher the number, the leaner your car is running. The lower the number, the richer the car is running. If your 16V is getting a reading of let's say 10-12mA, it is running too lean. If your 16V is getting a reading of 1-2mA, it's running too rich. Before actually messing with your mixture adjustment, CHECK for vacuum leaks, because they will throw the reading off. Most of this is pretty straightforward, I hope I'm not making it sound more complicated than it is.
What if your meter reads a constant number, and doesn't fluctuate? The most common cause of that is: a bad oxygen sensor.
What if your meter is hooked up correctly, but is pinned at zero? You car is set WAY, WAY too rich, and should be very sluggish to drive, and have no throttle response. Lean out the mixture slowly, until the reading starts coming up.
Turning the mixture screw clockwise will RICHEN the mixture, and of course turning it counterclockwise will lean it out. Never turn the screw more than an 1/8th of a turn at a time. You will see that it is very sensitive.
I HIGHLY recommend that all mixture checks and adjustments be done at night, so that you get consistent results. This is because the computer adjusts the mixture rich, during the day when it's hotter outside. If you check your car's mixture during the day, and it reads a lower number than what you set it to the previous night, don't worry, it's normal.
Stock settings:
1.8 16V-averaging 5mA.
1.8 8V-averaging 10mA
2.0 16V motronic-averaging 2.5mA.
Performance tuning:
Even a bone stock motor will benefit from a slightly richer setting. These are the settings I recommend for stock or mildly modified motors. The 16V settings are for maximum power between 4000 and 7000 rpms, so you might lose a little bit of low rpm power. If you would rather have the low-end, simply don't set the car as rich.
1.8 16V-averaging 3-4mA ("bouncing" off of 2.5mA)
1.8 8V-averaging 9mA ("bouncing" off of 8mA)
2.0 16V with CIS-E averaging 3mA ("bouncing" off of 2mA)
2.0 16V motronic - get a performance chip!
(what I mean by "boucing off of", is: the lowest number your reading drops to)
All cars will respond slightly differently due to mileage, local elevation, running condition, performance parts,...etc. All the settings I give you, are approximate settings.
Any questions, please e-mail me.
I explained how to do the fuel mixture adjustment, but maybe I should explain what you are actually doing.
I'm going to take the VW fuel injection, and make it sound horribly simple. It will help you in understanding the fuel delivery system of your car. This isn't exactly how the injection works, but if you think of it in this way, you'll understand what you're doing.
Your engine gets fuel in 2 ways, "mechanically" and "electronically".
The "mechanical" part, being the fuel mixture adjustment screw, which will supply x amount of fuel.
The "electronic" part being the full throttle fuel enrichment switch, which will supply a constant amount of fuel, a. a never changes. It is always the same.
a + x = total fuel to your engine.
When you adjust the mixture screw, x, you are changing the total amount of fuel going to your engine.
Once again, before the nit-pickers out there start attacking me, I know this isn't exactly how it works, but I want to put in terms that even non mechanically-inclined people will understand.
Miscellaneous stuff about changing the fuel mixture:
My friend has a CIS-E car, with a 2.0 16V. I have noticed that the fuel mixture is very sensitive. If the car is set at the stock 16V setting of 5mA, it will start up easy, idle nice, and have very good low end power, but not much high rpm power (the car will feel like an 8v motor). The setting that my friend actually runs his car at, 3mA, takes away a little bit of low end, and makes the idle a little less consistent, right after start up. But...this setting kicks ass at high rpm's.
I, once again, highly recommend that after every adjustment of the fuel mixture, you take your car out, and drive it hard. Get a good feel for your car, through the first 3 gears, and at part throttle, and full throttle. Small mixture adjustments will make the most noticeable difference at high rpms, in 3rd gear on the freeway
this is of great use to me too as my cars running well ill,i follow it all apart from how to actualy connect the meter,dont suppose you could do a little diagram or sumthing on how to connect the metre up? did you mean one meter probe on each wire? and if say the red probes on the wrong wire out of the two then it will be switched? or bothe probes on one wire?
thanks guys, that the mixture thing sorted out!! Gonna be having a go of that tonight - top info flusted, you may want to do another wiki! ;-)
SO that just leaves te timing to check, any ideas?
Good info that. I'll read it when it's not almost 1:00am and I'm not full of vodka!
hope the hang over isnt to bad mate! :-)
Sorry to drag this up again folks!
I have messed with my timing by ear and the car is sooooooooooo much better i couldnt believe it!
But i do get a split second of pinging before the ecu sorts it out (only on WOT in low gear) which makes me think i have gone a bit to far so if any one has some infor on the timing setup on a 9a i would = :D
pinking/pinging starts before it's audible, so I'd wind that dizzy back a bit, even if you've got knock sensors it's not good for the engine.
My 2L is set to about 8.5 degrees advance at idle, no pinking at all and was set up at Stealth, but then it's got a P&P head and I always run it on Tesco 99.
Base setting should be 6 deg +/- 1
You need a re-chip if you want more advance in higher revs.
Oo to time it up you just set the dizzy with a timing light at idle with out any need to dissconnect or change anything else (i.e the 1.8 16v you have to diss the red/black lead to set timing) its the whole kejet thing that has got me all confuzzled
And you are right dave i deffo need to knock it back a bit (or try 98 ron)
:D
:D
I'll check my Haynes passat manual, I'm pretty sure the 1.8 doesn't need any connectors removed, but the 2.0 may do, I'm running K-jet on a 2L block just to add to the confusion, never removed any connections on mine though and I'm pretty sure I followed the manual for the 1.8.
Nothing needs to be disconnected on the KR or 9A to check the timing. The Haynes Passat manual just says to clear all fault codes on the 9A before starting.
It just says:
1) Run the engine to normal operating temperature.
2) Stop the engine and connect a timing light.
3) Start car and allow to idle
4) Point timing light into access hole and line up flywheel mark with casing mark by turning the distributor. The timing mark is to the left of the '0' TDC mark at around 6 degrees BTDC.
...and that's it.
well thats Kool!
Ill give that a go tonight! I gave up trying to adjust the CO as my metering head has no adjustment hole like other i have seen, Ill just leave the ECU to sort that out :lol:
Thanks for the info guys, ill just use the tdc mark as i have a snazzy timing gun that you can set the advance on, so may even try a bit more advance
again :D thnaks guys!
Just make sure you use 6deg BTDC not 0deg, it's easy to mistake the two. IIRC 6deg has a lug sticking out of the flywheel which is used for VW's tool, and 0deg has a '0'.
well so far so good, timed it up using the '0' as i have a gun that you can set the advance on so i set that the 6 degrees BTDC and timed up using the afore mentioned tdc mark. all seems well and i was out so we will see in the morning :-)
thanks again for the help
I was led to believe you have to disconnect red7black wire at coil to time a 1.8 as it disconnects the ecu advance
