_leon_
tools for engine rebuild
I am about ready to start on a G60 engine rebuild project - standard rebuild with a new head, cam etc - and have the majority of parts ready, a garage to use and some of the obvious tools (stand, crane, torque wrench, usual sockets etc etc). I haven't done something like this before and have some material to help me through - but am positive I need to stock up on some essential tools. Can anyone give me a list of what tools I will definately need please?
mate not meaning to sound negative but ive been repairing cars for 21 years and every month i think i dont need anymore tools and then the dealers bring out a new bit and i have to buy another tool :( so the list could be quite long mate , hope all goes well with the rebuild :D
Piston ring compressor, valve spring compressor, torque wrench, angle tightening guage, assorted taps (to clean threads in block) and special sockets / spline drives for headbolts etc, plastiguage. Other measuring tools - micrometer, verniers etc
Air line is usefull to clear out crud from parts, most importantly - full manual or as a minimum of all the clearances and torque settings
@lottysvdub yeah i know - i never have enough tools. but thought an engine rebuild would require tools i dont normally need to know the name of ;)
@Scruffythefirst cool thankyou - i only need to change the valve stem seals in the head as its only covered 5k miles - but the block is getting overhauled. had thought of a steam cleaner - but the air line is a nice idea.
thanks
you'll still need a valve spring compressor to do that, but if its only done 5k i wouldn't bother.
the head has been sitting indoors for about 2-3 months though - a friend advised it would be worth changing the stem seals in case they dried out - any thoughts on that?
they shouldn't have dried out if they're that new... my engine has sat for 6 months without needing new valve seals... it's only when they're old and worn that leaving them can cause 'em to dry out... 8)
get somebody to do the head for you. for what it costs its easier and not a lot in it cost wise. no need to use a specialist in vw. just a good engine shop.
if you are putting in pistons and rings you will need at least a hone on the block too. otherwise compression will suffer as the rings wont bed in.
lots of spanners and sockets.
torque wrench.
if you are not used to it get a magnifer to inspect the crank and bores. then you will at least know whats in front of you.
12 point star for the headbolts.
thanks again guys - i wont be touching the head since its almost 'new'. a local engineering shop will be checking over the block, pistons and crank - also the head to make sure its straight. In addition they'll be doing the cleaning, honing, balancing of everything plus some strengthening of the crank. That way I'll know if i need it ground and need oversized bearings. I'll just be doing the assembly!
Good call about the head bolts!
