andiG60 0 Posted May 23, 2006 Hey all. help needed badly with my 2l 16v! Yesterday there was loads of water on the road. so i went through slowly, in the middle, with revs up, all was fine, drove at speed down the motorway for 40 miles. car running perfect. Stopped for 5 hours during work. Then car was hard to start. Thought it was damp, it started, i drove (hard) for about 30 mins to dry her out. Now DEAD :cry: wont start. when i turn the key, and pump the pedal, there is a swith on top of the engine which i think the throttle cable is connected to, it open full and the car feels like it should catch but wont???? Any ideas? A few months ago, i had major problems and i had a number of things wrong. i changed ECU, lamda, plugs, and module on the metering head which cost like 150 quid alone, as well as some sort of plug at the bottom of the engine was knackered Quote Share this post Link to post Share on other sites
davidwort 0 Posted May 23, 2006 Hey all. help needed badly with my 2l 16v! Yesterday there was loads of water on the road. so i went through slowly, in the middle, with revs up, all was fine, drove at speed down the motorway for 40 miles. car running perfect. Stopped for 5 hours during work. Then car was hard to start. Thought it was damp, it started, i drove (hard) for about 30 mins to dry her out. Now DEAD :cry: wont start. when i turn the key, and pump the pedal, there is a swith on top of the engine which i think the throttle cable is connected to, it open full and the car feels like it should catch but wont???? Any ideas? A few months ago, i had major problems and i had a number of things wrong. i changed ECU, lamda, plugs, and module on the metering head which cost like 150 quid alone, as well as some sort of plug at the bottom of the engine was knackered You need to narrow it down, electrical or fuel related? (1) Does it turn over? - think you say it does (starter solenoid can go) (2) Have you checked for a spark? (hall sender on dizzy can die) pull a plug put it on top of cam cover and see if you get a spark on cranking. (3) have you got fuel pressure to the injectors?, does the under car pump buzz? Quote Share this post Link to post Share on other sites
chrishill 0 Posted May 23, 2006 did you have the plug leads, dizzy cap and rotor arm changed when you had problems before? sounds like a spark issue to me, and if they've not been done they'd be the first place I'd look. -edit- sorry just noticed its a 2.0 16v, not a 1.8... did they still use a dizzy/rotor setup or did they change? Quote Share this post Link to post Share on other sites
andiG60 0 Posted May 23, 2006 it does turn over, i will check for spark when i get back after work. and the pump does prime when turning the key Quote Share this post Link to post Share on other sites
Blinky16v 0 Posted May 23, 2006 Did you sprayed WD40 onto the electricals? Sometimes helps disperse the water... Quote Share this post Link to post Share on other sites
andiG60 0 Posted May 23, 2006 yes and no. not wd40 but electrical contact spray. better than wd apparently, but to no avail Quote Share this post Link to post Share on other sites
Blinky16v 0 Posted May 23, 2006 Bugger... would've been nice if that sorted it. Sounds electrical to me, let us know how the spark check goes mate. Quote Share this post Link to post Share on other sites
ben16v 0 Posted May 23, 2006 yeah check spark, but dont rule out an ignition switch, mine went after a bit of fiddling my car :lol: just a coincidence but i was sure it was cos of me Quote Share this post Link to post Share on other sites
RapidVII 0 Posted May 24, 2006 Just a bit of pointless information here as im bored and have itchy fingers. WD40 - the "WD" stand's for Water Displacement. So there you go :lol: R7 Quote Share this post Link to post Share on other sites
VDUBBER 0 Posted May 24, 2006 What is the 40 for then? Iam also board if you couldnt tell? :roll: Quote Share this post Link to post Share on other sites
vr6storm 0 Posted May 24, 2006 it was the 40th formula that they tried and its true Quote Share this post Link to post Share on other sites
bcstudent 0 Posted May 24, 2006 Well if we're having a boredom contest, get a load of this! Quote Share this post Link to post Share on other sites
vr6storm 0 Posted May 24, 2006 another use for WD-40 according to the ppl themselves • Removes a Boa Constrictor stuck in engine compartment of cars always wondered how you did that Quote Share this post Link to post Share on other sites
andiG60 0 Posted May 26, 2006 right! think i solved it. i got the the car running but within a few seconds of starting, it would run super weak and start backfiring from the front end!. as i changed the acuactor last time the car was playing up, i disconnected it and then ran fine??, so, im assuming a fault with the signal from the lamba as,dispite changing this just before xmas, when ecu and actuator changed i cant think of anything else??? andy ideas? 0000, and i tried another acuator and ecu on the car, but same symptoms Quote Share this post Link to post Share on other sites
bcstudent 0 Posted May 26, 2006 The Lambda probe works in open-loop mode when the car is cold so if you've got running problems on a cold start it won't be that. For cold-running fuel enrichment the temperature sender signal is used by the ECU I believe. It makes sense that the car runs fine for a few seconds as that's about as long as the cold-start injector will be operating. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted May 26, 2006 I hear the G60 ECU does a lot of fuelling based on this mysterious 1m-long vacuum hose.. Best check that's *exactly* 1m long too..! Quote Share this post Link to post Share on other sites
bcstudent 0 Posted May 26, 2006 That may well be true...but this is a 16v running problem! Quote Share this post Link to post Share on other sites
andiG60 0 Posted May 26, 2006 But if i disconnect the actuator (when cold) the car will start, she does not like it very much but will start. when up to normal temps, if i kill the engine and restart, same problem. so it happens regardless of if the engine is hot or cold. Quote Share this post Link to post Share on other sites
exturbo2003 0 Posted May 28, 2006 fuel pump pressure problem or the injectors are leaking Quote Share this post Link to post Share on other sites
