biggerbigneil 0 Posted June 22, 2006 Hi Guys A bit embarrased asking this, just looking through the whole cooling system and got a bit tired blah blah, just replaced the header tank and a couple of pipes and was looking for the lowest pipe on the radiator to drain out the coolant. I knew this pipe was to small to be a coolant pipe but I removed it anyway - light yellow/green fluid came out. I don't know what pipe would be needing to go to the front of the car, just under the radiator unless it was an oil cooler. However I am thinking it is the power steering fluid - just don't understand why it is going to the radiator area... I know, I know What happened was, the hose clip on what I knew was the lowest coolant pipe has seized (it's one of the stupid clips with a screw) so I went looking for another pipe... How do I remove a seized clip/clamp? I've soaked it in WD40, tried various screw drivers and strange devices hooked up to a wrench, also borrowed a 9/32 socket piece from a neighbour which still didn't work. Ah the joys Quote Share this post Link to post Share on other sites
sciroccotune 0 Posted June 22, 2006 there is a loop type cooler for the power steering fluid. so my guess is the same as yours :-) Quote Share this post Link to post Share on other sites
Tom_vRS 0 Posted June 22, 2006 Er, yellow green fluid is coolant in my books! Especially if it goes to the radiator! Quote Share this post Link to post Share on other sites
biggerbigneil 0 Posted June 22, 2006 I think it is power steering fluid, I don't think it is coolant, because I have filled it with water only, ready to start flushing the system and only a couple 100 ml of this yellow/green stuff came out. I'm still not 100% sure though. I'll just check where the pipes go when it is light enough, yes I was working in the dark, school boy Quote Share this post Link to post Share on other sites
Henny 0 Posted June 22, 2006 rubber pipe going onto a metal pipe which goes through the panel under the radiator, turns 90 degrees, runs just behind the spoiler for about 18" and then turns back and goes out back through the metal panel under the radiator? Yup, that's the power steering fluid cooler pipe... :roll: Quote Share this post Link to post Share on other sites
biggerbigneil 0 Posted June 22, 2006 Henny, yup that's be the one... my bad, I thought it was, just too dark to check the level of the power steering fluid and I was too tired to botherchecking where all the pipes go - numpty Thanks for the help, I take it I can just top it up with VW stuff, or is there a special VR6 only formula? Is there a way of breaking this stupid clip on the bottom rad hose? Can't remove it for the life of me, surely someone has had to deal with a seized one of these? Quote Share this post Link to post Share on other sites
Henny 0 Posted June 22, 2006 nah, it's the standard VW green stuff... The only way I've ever found to get knackered jubilee clips off is with a sturdy pair of side cutters onto the side of the worm drive... :| Quote Share this post Link to post Share on other sites
bcstudent 0 Posted June 22, 2006 Look on the bright side, at least you know it had the correct PAS fluid in there! Quote Share this post Link to post Share on other sites
biggerbigneil 0 Posted June 22, 2006 ha ha true I was a bit concerned that the old header tank was covered in a yellow/orange deposit but after filling it up and blocking off the pipes I could see there was a crack in the tank. I don't think my heater matrix was gone after all that. Bring it on MOT inspector! Quote Share this post Link to post Share on other sites
Andy Brookes 0 Posted June 22, 2006 There is a drain plug on the crack pipe (plastic pipe that runs between the thermostat housing and the waterpump) for future referance. Quote Share this post Link to post Share on other sites
biggerbigneil 0 Posted June 22, 2006 Cheers Andy! Didn't realise that was were you kids drained the coolant from, I'll be creating a how not to guide very shortly! I make so much mess when I play with fluids, I should really leave the engine bay to the professionals Quote Share this post Link to post Share on other sites
