Shaggy 0 Posted July 6, 2006 Can somebody tell me what would happen if the 1m long ecu vacuum pipe was either too short or too long?? I have heard of leaks in the system but what would happen if the pipe not at the correct length? WOuld this play havoc with the ecu? Cheers Quote Share this post Link to post Share on other sites
flusted 0 Posted July 6, 2006 i guess so yes,as it would register more or less vacuum or boost. I remember using different lengths of pipe on my actuator on my metro turbo to increase the boost :oops: Quote Share this post Link to post Share on other sites
W3RKD 0 Posted July 6, 2006 +/- 10mm No there will be no signs. Quote Share this post Link to post Share on other sites
Supercharged Junkie 0 Posted July 6, 2006 I had one that was 10cm too short and it made a difference when i got the correct length pipe on there :-) Quote Share this post Link to post Share on other sites
Shaggy 0 Posted July 6, 2006 It just occured to me last night that if i am at the limit of my map sensor at 15 psi that a shorter ecu vacuum would effect my car more than others as i am making greater boost. i am going to conduct an experiment tonight and put on a new vacuum pipe which is exactly 1m long and see what the old one measures. :-) Quote Share this post Link to post Share on other sites
Shaggy 0 Posted July 6, 2006 just measured my one, its 25mm longer than it should be @ 1025mm?? Anyone know what the correct Internal Diameter should be? Quote Share this post Link to post Share on other sites
Crasher 3 Posted July 6, 2006 The odd thing is that the original pipe from new was rarley 1000mm, often much shorter! Quote Share this post Link to post Share on other sites
2_Door_fun 0 Posted July 7, 2006 Mine was 3m yes thats 3 meters long :lol: Car still ran ok was abit advanced though. Quote Share this post Link to post Share on other sites
