mr_fusion
The 'Running a Rotrex charger on a VR6' thread..
C30-94 (not one of them dodgy old rotrex's with the old style oil wotsit ;) )
Bracket, pulley, belt, etc etc
Oil reservoir and lines
All samco pipes
Red tops
6-branch
Recirc valve
Auquamist
Fitting
Mapping (with MAF as he said the rotrex is too badass to go MAFless?)
Anything else needed that I've forgotten.
pah! mine has the super duper front mounted oil cooler, not yer cheap naff cost cutting reservoir with fins on it lol
sounds like a good deal mind.
wonder how much it will end up cost me for all the bits....
lol :)
The only expensive bit you need is the bracket from what I can make out? I reckon you could get one made for about 60 or 80 quid tbh.
The charger's are expensive - the only place I've seen doing them on their own are knocking them out for 1600 quid plus shipping and maybe a bit more tax! So 3300 for the whole lot with aqua and a 6-branch & redtops is pretty darn good I reckon.
So do ya reckon leave the shrek on or what? What about selling it and getting one of those schimmel short runners for less money?
i think i will have to travel down, and have a go in the black beast when its got the rotrex on Will 8)
if it was me, i would sell the schrick, and get the schimmel manifold mate. much more responsive at take off, plus been told, more torque than a schrick when using a charger.
and that sounds like a very very good deal £3300. :shock:
karl
So it would be more responsive with the short-runner intake mate? Is that cos of less volume of air to 'move around' or what?
I don't understand the SR intakes at all.
Did you end up getting a C2 one and a chargecooler mate?
i have the chargecooler as above sitting in the garage mate, along with ARP bolts, but the C2 manifold does not fit in the rado, so gotta do some saving for the schimmel. :(
as for cams i'm sure its the 248's for FI, or even standards will do the job fine..
  StormchargedVR6 said:
Im going down the schimmel route, its the only way forward :)
Got my 15psi pulley ready :lol:
yeh cheers for reminding me Shaun :( you beat me to that pulley didn't ya
Sorry bud :)
Just remember with short runner you need slim line fan, and the cooler you need to put your battery in boot.
  double-6s said:
Battery not a problem. But you have to change the fans? How come? And how much?
Short runner won't fit, you only need one 11''spal fan. There about £60, get one on ebay. Thats what im going to be using
  double-6s said:
And is it a straight swap? Anything else need changing fan-wise?
Just bit of wiring. If your going charger mate you better getting an oil cooler too. :oops: Sorry bud just seen you got one
It's because the throttle is close to the head - less distance for the air to travel. For forced induction, the smaller the plenum size, the better, again because it's a shorter distance into the cylinders which reduces lag.
What boost are SD going to run your kit at? Are they dropping the compression? No mention of inter/chargecooling though?
Do they still need the car for 5 days?
