-Neil- 0 Posted August 7, 2006 im new to the VR6 scene and when im igniton is on, there is a buzz coming from the back right of the engine as you look at it from the front of the car, it sounds like a fule pump priming but its on the engine? Any ideas what it could be? Quote Share this post Link to post Share on other sites
Mr Sands 0 Posted August 7, 2006 I know the part you mean. I'm afraid that, ignoramus that I am, I don't know what it is. However, mine does this too and doesn't seem to be a cause for concern! Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted August 7, 2006 Its a run on electric water pump mate , nowt to worry about , its supposed to that ;-) Quote Share this post Link to post Share on other sites
Mr Sands 0 Posted August 7, 2006 There we go, I thought someone who knew what they were doing would be along in a minute! Quote Share this post Link to post Share on other sites
Heardy 0 Posted August 8, 2006 Yep it's the coolant run on pump Neil, i heard it the other day when i had a look around it. It does make a bit more noise than usual. Quote Share this post Link to post Share on other sites
-Neil- 0 Posted August 8, 2006 Ill look into it and see if its a costly job! Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted August 9, 2006 Just keeo an eye on it. Look for any coolant residue on the hoses/connections. If you end up changing it, it's an easy one :wink: When I did mine it was around £55 from the dealer. Quote Share this post Link to post Share on other sites
dinkus 10 Posted August 9, 2006 Mine's also died recently (makes a horrible plasticy grindy noise) and am awaiting a call from the yokel stealers to see how much a replacement will be... Quote Share this post Link to post Share on other sites
