flusted 0 Posted August 9, 2006 http://cgi.ebay.co.uk/BN-Universal-4-Wire-Oxygen-Lambda-Sensor_W0QQitemZ120014908632QQihZ002QQcategoryZ72205QQrdZ1QQcmdZViewItem Mine is completly dead,will this fit and work ok? mine is 4 wire Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted August 9, 2006 you sure its not 3 wire even though it has a 4 wire plug the earth just grounds on teh engine mount,, part you want is from GSF,, not listed for corrado but has teh correct plug and wiring and is cheap as chips,, part no gsf is,, 93032 Quote Share this post Link to post Share on other sites
flusted 0 Posted August 9, 2006 £49 plus vat from gsf :cry: It is 3 wire now you mention it as it has the earth to the bracket. Can i buy the ebay 1 and just put a ring terminal on the earth wire? Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted August 9, 2006 if you haggle you will get it for cheaper than that all in,, just say you want club discount,, no point messing about, do it once do it properly Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted August 9, 2006 hi aide well glad you got to run right will be a beast now when you get new lambda then we can do some driving! with the massive intercooler was sort of heat where you seeing in the temp gauges? Quote Share this post Link to post Share on other sites
mr.brown 0 Posted August 9, 2006 part you want is from GSF,, not listed for corrado but has teh correct plug and wiring and is cheap as chips,, part no gsf is,, 93032 I'm running one of those - it's listed for a mk3 Goof iirc Quote Share this post Link to post Share on other sites
Andy T 0 Posted August 18, 2006 Cheap lambda's won't work as well as the genuine VAG Bosch item and will only last a year if your lucky. They are different part numbers for each engine type, G60 is dealer only (was last year anyway) Quote Share this post Link to post Share on other sites
flusted 0 Posted August 18, 2006 I bought 1 anyway and it still hasnt cured my problem :drinking: Quote Share this post Link to post Share on other sites
