bighands 0 Posted August 9, 2006 Right, so always thought the timing was out on the golf, so i have had a go at setting it up myself, found TDC with the screwdriver down the plug hole method, and found the flywheel timing mark, and the mark in the crank pully, on the plastic cover and all matched spot on, set the distribtor to dead on 1, and set the cam timing to TDC, on the side of the head, and now it feels like its got a potato stuck in the exhaust?!?!?!? What have i done wrong?? oh its a golf 1.8 E and hqs carbs, not even injection!!! Not corrado but VAG :-) Andy Quote Share this post Link to post Share on other sites
crdo16v 0 Posted August 9, 2006 maybe the engine's had it's chips :chef: , sorry mate couldn't resist that one. Quote Share this post Link to post Share on other sites
bighands 0 Posted August 9, 2006 Poor, very poor lol Sod it think i will put it back to 'wrong settings' as cant be arsed to fook around with it somethings slipped or i dunno but it isnt right!!! Andy Quote Share this post Link to post Share on other sites
bcstudent 0 Posted August 9, 2006 You've set the distributor to TDC? Shouldn't it be set to the six degree mark on the flywheel? Quote Share this post Link to post Share on other sites
goodridge 0 Posted August 9, 2006 Sounds like the timing could be out. You need to check the mark on the auxilary shaft matches the one on the crank pully. And then the rotor arm should point to the notch on the distributor body Quote Share this post Link to post Share on other sites
Henny 0 Posted August 10, 2006 bcstudent, and we have a winner... ;) Yup, bighands, you've just successfully set your engine up to fire at TDC, not at 6 degrees... :roll: Time to get a timing strobe out and set it up properly again.... ;) Quote Share this post Link to post Share on other sites
bighands 0 Posted August 10, 2006 Great sounds like fun! I put it back to the way it was so it actually runs, but has always seemed to lack in the high revs and idle +-1000 revs all over the place! I think the TDC mark is on the pully on the bottom timing pully, it lines up with the mark on the plastic cover, and through the flywheel it lines up not really a 'O' but more of a punch hole?! lined the cam sprocket up with the inner line and the edge of the top of the head and the dizzy with No1 mark? But you say it should be 6deg before?? would that be the line about an inch and a half or so to the left of the 'O' on the flywheel, looking from the passangers side to the drivers through the flywheel hole?? Andy Quote Share this post Link to post Share on other sites
bighands 0 Posted August 10, 2006 Ah set it to that, and SHE A BEAST!! But has now made it even more apparent that the clutch needs replacing, the extra power means slippage :-( if it isnt one thing . . . . . Can lock this now, cheers for the advice! Andy Quote Share this post Link to post Share on other sites
bcstudent 0 Posted August 10, 2006 If only all problems were that easy to solve! Glad you're sorted chap. Quote Share this post Link to post Share on other sites
Crasher 3 Posted August 10, 2006 What Golf is it and what is the engine number? Quote Share this post Link to post Share on other sites
bighands 0 Posted August 10, 2006 errr i dunno, its a MK 2 with the altonator down the bottom not on the end of the cam, and not cross flow, aka inlets and exhausts go in the same side?!? Quote Share this post Link to post Share on other sites
