chaz g60
g60 starting problem (please help)
My 92 g60 is starting and cutting out striaght away if reved it strugles but dies, i've checked the fuel pump but seems fine and filters new.
Had it on vagcom with no response and changed the blue temp sensor.
Before the problem started i felt it judering like kangarooing a bit but still ran ok She's been in my work for a week now and im getting desperate, please any idias appeciated??
Also if the sensor thats causing the grief is in the ECU how do i remove it??
Cheers , Chaz. :cry: :roll: :cry: :roll: :x :x :cry: :x
Yeah i checked the lift pump and tried replacing it but can't find the right one
Seems to of been superseeded, I work in G.S.F. and cant get the right pump here either but it's working anyway. could be the presure reg i spose.
Try the Idle Stabalisation Valve or ISV it sits on top of your cam cover near your throttle body. Give it a clean out if its dirty with some Carb Cleaner or it maybe knackered???
Yeah first time everytime then she dies??
lookin like it could actually be the £125 pound lift pump!!!!
Am i right in thinking this is the only fuel pump on a g60?? :roll:
I'd check the ISV as well as the fuel pumps. When mine started cutting out, it was actually one of the wires to the ISV which had come into contact with the head, and burnt through.
on the early cars there are 2 pumps. 1 in the tank and 1 under the car (like the mk2)
on the later cars there is only 1 combined pump in the tank.
