catch_twotwo 0 Posted September 24, 2006 Got my car back after some heavy work at the mechanics...... one of the new things was the 13 bar Mocal Oil Cooler (thanks Flusted). So the advice I had was to not trash (i.e. go over 3000rpm) till you hit 80° for the oil. So It's filled with nice new Mobil-1 and I took it for a nice little drive waiting for the oil to hit that magic number.... after 15 km it was still hovering at about 76°. So what can I do to change this... as having a nice fast car is pointless if you're not able to drive it fast ;) For info... the Oil Cooler is fitted behind the front gill longways next to the radiator. So fitted well (possibly too well) for air flow. Quote Share this post Link to post Share on other sites
Furkz 0 Posted September 24, 2006 1st time i drove mine after fitting mine it didnt go over 76deg for abt 20 miles lol i was well annoyed Quote Share this post Link to post Share on other sites
_leon_ 0 Posted September 24, 2006 do you still now wait till it hits 80? Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted September 24, 2006 Where have you fitted the oil cooler?? Quote Share this post Link to post Share on other sites
Furkz 0 Posted September 24, 2006 no, just start driving it normally and dont really go over 3k for the 1st 10 mins Quote Share this post Link to post Share on other sites
LowG 0 Posted September 24, 2006 Maybe you have fitted a non thermostat sandwich plate on there? Its best to use sandwich one, saves on warmup time and bit of fuel also. For summer is ok but now in winter it can get too cool, same happened to me when I ran a straight plate. Quote Share this post Link to post Share on other sites
HVB G60 0 Posted September 25, 2006 You can order thermostats that open at a higher temperature. I've got a 80 degrees fitted in mine, where the standard one starts opening at 74. Now I can clearly see the temperature gets up to 76-78 rather quickly, and after that it needs a while longer for the temperature to rise above that level. But at that point you can give a little bit of boost and rev the engine somewhat higher than 3000rpm, so that the temperature will rise. Quote Share this post Link to post Share on other sites
Walesy 0 Posted September 25, 2006 Do you still have the original oil cooler aswell? Quote Share this post Link to post Share on other sites
Pickard1 0 Posted September 25, 2006 This happens to mine too. It rockets up to 78oC and then slows right down. Obviously there is some calibration error between the sandwich plate and the MFA oil temp. The plate is opening at 78oC, hence the slow down in temperature rise. Id say it takes about 15 mins to get up there, depending on how many revs you are giving it. I still play it safe and wait for 80 on the MFA, even though it is an extra 5 mins. Im (un)fortunate that I mainly do longish journeys so its not too bad - it always gets there eventually. If I was pottering around town and it never got to 80 to floor it then I might look harder for a solution. It may be that at 15yrs old the oil temp sender has drifted out of calibration. A new one might be 'in line' with the thermo plate? But equally it could be the plate that is releasing too early. Quote Share this post Link to post Share on other sites
dubburke 0 Posted September 25, 2006 Any pics of where people have put the oil cooler on their G60? which one have you gone for? i was thinking of an uprated oil cooler as i have seen people talking of 130 degree oil temps on their G with standard oil cooler. Quote Share this post Link to post Share on other sites
catch_twotwo 0 Posted September 25, 2006 Where have you fitted the oil cooler?? It's fitted vertically behind the grill, right next to the radiator. As I had a mechanic fit this I'm not sure if he removed the original oil cooler, but I doubt it. Langauge barier is a little more than I can get over, so things don't always get done as I request... still it gets done. Is removing the original oil cooler (sandwich plate right) easy to do ? Any pics as I'm not sure where it is in the engine.... My cooler hasn't got a thermostat so it's always on.... temp starts at about 56° after a few minutes and then creeps up from there. So the temp looks accurate, just the oil cooler doing a great job. The temps quite hot here still (at least was at the weekend) it was 24° in Austria and driving fast to heat the oil just got more airflow to the cooler and made the temp reduce 2° :mad: Quote Share this post Link to post Share on other sites
ZippyVR6 0 Posted September 25, 2006 Put a sock over it. In winter this might be the only way to get things above 80. Quote Share this post Link to post Share on other sites
_leon_ 0 Posted September 25, 2006 :lol: good option... Quote Share this post Link to post Share on other sites
G60SC_Stoney 0 Posted September 25, 2006 i had the same problem with my oil cooler...way i fixed it was putting a 65mm toothed pulley on!! :lol: now i manage to see 98 when stuck in traffic!! Quote Share this post Link to post Share on other sites
double-6s 0 Posted September 25, 2006 Just get a VR mate. You'll soon see much higher temperatures! :) Quote Share this post Link to post Share on other sites
Pickard1 0 Posted September 25, 2006 I think the original oil cooler has been removed, else the water would heat the oil up eventually?? Perhaps you should get a thermostatic valve. Otherwise some tinfoil. :lol: Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted September 25, 2006 or do 150 on the autobahn for a few miles im sure that'll see a few more degrees! Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted September 26, 2006 A thermostatic sandwich plate is essential really. Without it you’ll never get up to temperature in the winter and your engine will run too cool for too long. Minimise the time the engine is warming up (and doing most damage) and get the cooler to kick in at 90 degrees. You can still drive enthusiastically at 78 degrees, the oil is warm and sufficiently viscous by then. There’s no need to be massively obsessed with the “magic 80 degrees”, as long as it’s warm it’s fine. Without a thermostatic sandwich plate though you’ll be doing more harm than good especially if you do lots of small journeys. Quote Share this post Link to post Share on other sites
catch_twotwo 0 Posted September 26, 2006 Where does the thermostat fit in the system ? As I guess I'll have to install this myself and I'm not good at engines ;) Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted September 26, 2006 It be sandwiched betwixt the oil filter and the engine ;) (then the feed and retun are connected to the plate) They look like this: http://64.202.180.37/files/sp1t.pdf#sea ... 20plate%22 Quote Share this post Link to post Share on other sites
fla 9 Posted September 26, 2006 betwixt - now there's a word :lol: Quote Share this post Link to post Share on other sites
2_Door_fun 0 Posted September 27, 2006 I have a 13 row cooler fitted to a MK1 gti filter head. Oil comes up to temp easily and even in the current cool weather. Should be interesting to watch it as Winter comes on. Quote Share this post Link to post Share on other sites
