steveo29
g60 runs rich? when cold engine*UPDATE*
anyone with a sns chip have cold running issues ?
mine chugs and bogs when the engine is cold and sounds almost ready to stall
any ideas
I had a similar problem with my G60 when cold, replaced Lamda sensor with a new genuine VAG one and this sorted the problem, cheers Dave
Post up some resistance figures across the 2 pins on the blue Coolent sender whilst running up from cold. Lets see if its that thats playing up.
okay ive taken some readings
outside temp 17deg engine cold i got 2.8 ohms with the meter on a 20k setting
after 1 min running time 2.0 ohms
after 2 mins running time 1.3 ohm
engine hot and oil at 86deg 0.25 ohms
hows that sound
