rysa20 0 Posted October 28, 2006 65mm Pulley on a G60 im currently running a 68mm pulley and was looking for more power so i thougt of upgrading the pulley to a 65mm . If i do this what psi would the g-lader produce then???? power increase?? cheers Ryan the engine has 110k on it would it be safe to run more boost?? Quote Share this post Link to post Share on other sites
flusted 0 Posted October 28, 2006 Ive just gone to a 65mm and its brilliant. Dont try and aim for high psi numbers as this just shows that your engine is wasting boost. Ive hit 18psi on a boost gauge with it though. You wont really be able to rev the engine over 6k though Quote Share this post Link to post Share on other sites
rysa20 0 Posted October 28, 2006 flusted any iea of the power you gained by changing the pulley?? Quote Share this post Link to post Share on other sites
g60bv 0 Posted October 28, 2006 it is noticeable. i would think about 15 to 20 bhp. try it. just check the fueling. not normally a prob. most g60's run rich anyway. Quote Share this post Link to post Share on other sites
Andy T 0 Posted October 28, 2006 Surely you'd need to get a custom map for it to work properly. Your engine might take it but from what I've heard you'll be having the charger rebuilt often Quote Share this post Link to post Share on other sites
rysa20 0 Posted October 28, 2006 sound chaps its currently running these mods any idea on power at the wheels?? its got sns stage 5 chip s4 g-werks charger 68mm pulley red top injectors full miltek exhaust de-cat pipe rs outlet k&n panel filter, drilled airbox Quote Share this post Link to post Share on other sites
g60bv 0 Posted October 28, 2006 wheel power varies from car to car. engine power.prob 200 210. put the 65 on. 215 220 std cam? if so get a piper 270h. not the 285. keeps the power low down. its excellent. Quote Share this post Link to post Share on other sites
rysa20 0 Posted October 28, 2006 Have you seen the gains that g-werks heads give ???? As fitted to the Golf and Corrado. The supercharged G60 engine fits the role of supplying lots of low down power from a small engine. Benefiting from a supercharger means lots of low down punch and no turbo lag. However, if you want to release the full potential of your VW G60 engine you must address the restrictions of the standard head. Any effiiciencies found in the head will be multiplied by the supercharger. We have measured our G60 head as if it were a normally aspirated engine. This is because supercharger boost cannot be easily simulated and has many variables such as barometric pressure, ambient temprature, intercooler effiiciency and level of boost used. We are working on a model for turbocharging and supercharging engines but for the moment we only have figures the head as if it were normally aspirated. This at least gives a fair benchmark of the improvements made. Our G60 head shows a very healthy inlet increase of 30.9 % peak flow rate at max valve lift is seen here along with a substantially improved flow rate across the valve lift range. Exhaust improvement is 26.9% improvement at the max valve opening. These are substantial gains and will benefit the delivery of the power low down as well as peak power overall. This head will produce 156BHp without a supercharger at 6500rpm. Our estimate is 190BHP at standard 6psi boost. More is possible with higher boost although you may also wish to consider our big valve version of this head may be worth a look got any pics of your G then mate?? Quote Share this post Link to post Share on other sites
_Monkey 0 Posted October 28, 2006 Only thing is, a 65mm pulley reduces your re-build intervals! 65mm = Suicide Pulley :lol: Quote Share this post Link to post Share on other sites
rysa20 0 Posted October 28, 2006 Only thing is, a 65mm pulley reduces your re-build intervals! 65mm = Suicide Pulley :lol: What would be the recommended charger service interval on this 65mm pulley?? Quote Share this post Link to post Share on other sites
dubburke 0 Posted October 28, 2006 I wouldnt risk anymore than 20k Quote Share this post Link to post Share on other sites
flusted 0 Posted October 28, 2006 20,000miles Quote Share this post Link to post Share on other sites
Rustynuts 0 Posted October 28, 2006 Does that 3mm really make such a big difference? The standard pulley being 78mm, so going down to 68mm usually only gives about 25 bhp over standard (as a standalone mod) So another 3mm surely only gives a max of 5 -10 bhp surely? However, i guess through the revs you will notice the difference. Also i guess stopping the boost leak that the ISV is designed to produce would also benefit. Quote Share this post Link to post Share on other sites
g60bv 0 Posted October 29, 2006 ERM.. yes the difference betwine a 68 to a 65 pulley is hugh, it IS worth doing., # lets face it. your g60 engine is GOING to get serviced before it gets to it @recommended@ service anyway. so just chuck on a 65mm pully and enjoy. i've used one for 3 years and any havent had any supercharger probs yet!! Quote Share this post Link to post Share on other sites
rysa20 0 Posted October 29, 2006 my charger has done about 10k since the last overhaul at g-werks are you all saying that with the 65mm pulley id only get another 10k till it needed another overhaul Quote Share this post Link to post Share on other sites
_leon_ 0 Posted October 29, 2006 thatr'd be advisable. but if youre not 100% sure i'd ask gwerks themselves Quote Share this post Link to post Share on other sites
rysa20 0 Posted October 29, 2006 yeah will do darren knows his stuff thats for sure Quote Share this post Link to post Share on other sites
Andy T 0 Posted November 2, 2006 Going from std. 78mm to 68mm is a 15% charger rpm increase, 78mm To 65mm is 20% rpm increase, not a massive difference but 20% must just surpass what the seals can cope with reliably. Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted November 2, 2006 Judging by the mods you've got you might want to consider a ported downpipe and ported exhaust manifold or a stainless manifold. That'll give you a load of low down torque. andy554 had this done and made a slug more grunt. Also I'd imagine you'd benefit from an oil cooler. At the moment, I'm surprised you need red top injectors. I had a similar spec to you with a Newman 268/272 cam and when setting it up the wideband showed that the greens were holding up fine. Quote Share this post Link to post Share on other sites
_leon_ 0 Posted November 2, 2006 got a 4 branch on mine - great mod tbh. Quote Share this post Link to post Share on other sites
g60bv 0 Posted November 3, 2006 wwwwwwwwwwwwwwwwwwiiiiiiiiiiiiiiiiinnnnnnnnnnnnnnnnnneeeeeeeeeeeeeee Quote Share this post Link to post Share on other sites
G60SC_Stoney 0 Posted November 4, 2006 could always run a BBM charger...... Quote Share this post Link to post Share on other sites
