2corrados 0 Posted October 29, 2006 Me Again have had a look and can't find anyone who has had the same problem. Only picked car up this weekend, but is tidy, has had new plugs and leads. Problem is when car is over 80 degrees (Oil) it occasionally cuts out entirely very briefly and then is fine again for a bit, then does it again. Its not fuel as the rev counter dips briefly and then comes back again, in time with the car cutting out and in again. Drove 170 miles today and got no better or worse, only occurs when hot. Temps were all fine steady 80mph water 70 oil 88 to 94. I am confused It is a tidy 1.8 16v LHD with 77k and a nice black leather interior which is going in my VR6, but car is too good to throw away Any help gratefully received. Dic Quote Share this post Link to post Share on other sites
Crasher 3 Posted October 29, 2006 It is a common problem and probably only needs setting up, something any decent VW specialist can do. Quote Share this post Link to post Share on other sites
Adam Darby 0 Posted October 30, 2006 Its not the sensor in the dizzy is it, this can be repaired quite easily if it is. go to the second page on this link and read what crazy dave has put about fixing it. http://the-corrado.net/.archive/forum/viewtopic.php?t=48136&postdays=0&postorder=asc&start=15 Quote Share this post Link to post Share on other sites
2corrados 0 Posted October 30, 2006 ok gonna see about the dizzy. have the vag garage doing a behind the scenes vagcom on it tomorrow, and will let you know what happens. does bring a whole new meaning to kangaroo petrol tho..................lol Quote Share this post Link to post Share on other sites
Adam Darby 0 Posted October 30, 2006 when it did this on mine it did not show up on the vag com, only if it was doing it whilst the vag com was pluged in. Quote Share this post Link to post Share on other sites
Crasher 3 Posted October 30, 2006 You will have trouble code reading it unless it is one of the super rare PL engined 1.8 16v's, the KR has no diagnostic ability. Quote Share this post Link to post Share on other sites
2corrados 0 Posted October 31, 2006 mmmm, I didn't know that. Will have to check. So none of the 1.8's have a diagnostic circuit then ? Any others thats dont't, just so I know for future reference. Cheers Dic Quote Share this post Link to post Share on other sites
Crasher 3 Posted October 31, 2006 The KR1.8 16v engine never had any form of diagnostic ability whatsoever and European G60's didn’t where certain later US market versions did. I had to double check this morning but I was wrong about rare PL engined models with diagnostics, they wasn't one with the PL. The 2E and ADY 2L 8v's, 9A 2L 16v's and VR6's all had diagnostics. Quote Share this post Link to post Share on other sites
2corrados 0 Posted October 31, 2006 ok, thats very informative, but I have a query. Why then does this 1.8 have the plug in sockets for whatever underneath the gear gaiter. Why is it there if it's not used ? Anyway, thats getting away from the problem. Any ideas as to the problem in hand ? Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 31, 2006 ok, thats very informative, but I have a query. Why then does this 1.8 have the plug in sockets for whatever underneath the gear gaiter. Why is it there if it's not used ? Anyway, thats getting away from the problem. Any ideas as to the problem in hand ? perhaps it's just a standard loom regardless of engine on that age of car, doesn't appear to be engine specific on ETKA. My 1.8 16v has a single connector there, but it appears to just be an ignition switched live and an earth (red and brown wires) I assumed it was part of the loom for illumination of the rear ashtray or something, never checked it really. If your problem was the hall sender in the dizzy I'd imagine the car would refuse to start though. David. Quote Share this post Link to post Share on other sites
2corrados 0 Posted October 31, 2006 this one has 2 twin connectors. must be for something ? Anyway gone for MOT so not back until Friday. Will see what I can do wirth it over w/e but any thoughts on cutitng out problem would be appreciated. Quote Share this post Link to post Share on other sites
2corrados 0 Posted November 2, 2006 news from the mot.pretty good really. have not found any fault with dizzy, so still hunting for problems any further help would be appreciated. 2 connectors were for the abs diagnostics, nothing else. someone else must have had the same problem Dic Quote Share this post Link to post Share on other sites
2corrados 0 Posted November 13, 2006 well, got the motor back, all fixed for mot. The hot misfire I think I have solved with the usual help from the forum, turned out to be the coil. I swapped the one of my 2l 16v and took it out for an hour. Got really warm, and behaved itself so hope it's sorted. Bought a new coil and will fit that tomorrow. Thanks to everyone, and if it comes back i'll let you know. Dic Quote Share this post Link to post Share on other sites
