potatonet 0 Posted November 1, 2006 ok guys turned the car off at 6:50 pm tried to turn it on at 7:30 am and my battery was dead, just had the battery replaced (month ago) and the alternator is putting out 14.1V... it slowly leaks out, this has happened a few times in the past month, but my question is what is a common source of this problem in a corrado? my friend said it might be my sunroof motor... Quote Share this post Link to post Share on other sites
catch_twotwo 0 Posted November 1, 2006 If you suspect it then remove the fuse and see ? Quote Share this post Link to post Share on other sites
CrazyDave 0 Posted November 1, 2006 I'd disconnect the battery, and connect an ammeter in series with the live lead. Then pull all the fuses one by one until you see a big drop in current. Sounds like you've got quite a big drain going on so shouldn't be to difficult to find. Quote Share this post Link to post Share on other sites
craigowl 0 Posted November 1, 2006 A number of us have reported mysterious battery draining behaviour with the Corrado. Our cool, wet climate for about seven months of the year does not help! Quote Share this post Link to post Share on other sites
Phil K 0 Posted November 1, 2006 Some people have found it's the boot light not turning off however I doubt that would drain your battery that quickly! Mine is down to 10V and will not start if left for over 24hr... I suspect the alarm brain and need to get it looked at soon but for the time being I'm disconecting the battery or if it gets too low sticking it on charge in the shed... bloody annoying having to reset the clock and stereo settings every time I want to take the car out though :? Quote Share this post Link to post Share on other sites
potatonet 0 Posted November 2, 2006 crazy dave = my hero, never would have thought of that and Im sure it will work. Quote Share this post Link to post Share on other sites
mattnorgrove 0 Posted November 2, 2006 you havent got that levitation thing hooked up still have you?? :wink: Quote Share this post Link to post Share on other sites
Toad 0 Posted November 2, 2006 Could it be the live feed for your supercharger clutch? Quote Share this post Link to post Share on other sites
