ardandy 0 Posted January 8, 2007 This has being going on for up to 6 months now, I'll give you the brief history and what its doing. What it's doing: The car drives fine, power. economy all seems to be as was. Sometimes (say 1 out of 8 starts) it starts with a little bit of a misfire, like it's waking up in the morning and getting the phlegm out of its throat! This stops after no more than 30secs. After this stops the car then decides to idle between 1,300rpm and 1,800rpm, no lower (like I've got my foot on the accelerator a little). When it gets warmer (I reckon when the auto choke disengages?) it then idles at around 300-500rpm, just above cutting out, fluctuating a little. It usually only carries on this for between 5 & 15 mins before going back to normal. It only seems to start doing this when I start the car, mainly when cold but has done it after being used. It has started mid-driving a few times though, just not often. When: Last Sept-Oct it did the above and then stopped doing it all together until the middle of December, when it started again. Like I say, about 1 in 8 starts, say 2-3 times a week. If you understand all this, any thoughts? :wink: Cheers Andy Quote Share this post Link to post Share on other sites
ardandy 0 Posted January 8, 2007 Oh, the idle control valve was cleaned when it was serviced at PSI in August. He did say a bit of oil was in or on (cant remember) one of the spark plugs. Could this be a cause? I also have cheap GSF HT leads on. Quote Share this post Link to post Share on other sites
nocrap 0 Posted January 8, 2007 It could be........have you had them out to check them? What about some of the cold start equipment? Sorry, what car is it? Quote Share this post Link to post Share on other sites
ardandy 0 Posted January 8, 2007 It's a VR6. Got back from 1 hours drive today, driving was fine but it was idling the whole time when stopped at 250rpm! Just wen out to move it and I couldn't get it started for quite a while! It was turning over as if it wanted to start but just couldn't quite get there! Once it did start it was idling at 1,200rpm then! Grrrrr! What the hell could it be? Wouldn't a spark plug do it throughout the rev range, where as this is only at idle? Quote Share this post Link to post Share on other sites
JIMMI 0 Posted January 8, 2007 Open the bonnet when its ticking over and listen for a hissing noise coming from the back of the engine ?? Quote Share this post Link to post Share on other sites
ardandy 0 Posted January 8, 2007 What would that be? Quote Share this post Link to post Share on other sites
vr6storm 0 Posted January 8, 2007 get someone to check it over on VAG-com its possibly a sensor going/gone Quote Share this post Link to post Share on other sites
ardandy 0 Posted January 8, 2007 It's going to PSI on the 20th, I'm taking it to a local (non vw specialist but v good) garage on Friday, he seems to think its the Idle Control Valve sticking? Too much rev's, too little revs? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted January 8, 2007 Sounds feasible. Quote Share this post Link to post Share on other sites
_Tony_ 0 Posted January 8, 2007 I had exactly the same fault on mine a couple of days back but mines an early 16v, a misfire on startup, then the misfire cleared but then it was idling between 300-500rpm. I knocked the ignition off, restarted it and it was fine. It hasn't done it before and hasn't done it since. Quote Share this post Link to post Share on other sites
ardandy 0 Posted January 8, 2007 Mine started, stopped after a few weeks and then was fine til a couple of weeks ago. Quote Share this post Link to post Share on other sites
ardandy 0 Posted January 9, 2007 Don't suppose anyone knows the part number for the Idle Control Valve? VW cant find it, the only thing they THINK it might be costs £550 and isn't in stock! Quote Share this post Link to post Share on other sites
dr_mat 0 Posted January 9, 2007 For god's sake, VW can't find it? Take the car there, point at the bloody thing... Quote Share this post Link to post Share on other sites
ardandy 0 Posted January 9, 2007 I would if I could get it started! He said its a circular type object on the air intake? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted January 9, 2007 He's talking about the bloody air flow meter, by the sound of it .. Idiot. Quote Share this post Link to post Share on other sites
ardandy 0 Posted January 9, 2007 Open the bonnet when its ticking over and listen for a hissing noise coming from the back of the engine ?? Yep, I can hear a hissing. Well at least I'm pretty sure I can! :) Whats that tell me? Quote Share this post Link to post Share on other sites
ardandy 0 Posted January 9, 2007 Cough cough. Quote Share this post Link to post Share on other sites
iow_corrado_g60 0 Posted January 9, 2007 the black breather pipe i just changed mine vince at stealth noticed but that was giving off a slightly hissing noise! on the left nack side of the vr bear the induction just my 2p thou. Quote Share this post Link to post Share on other sites
ardandy 0 Posted January 16, 2007 Does anyone know if the ISV is the same on the Golf VR6 as the Corrado one? Quote Share this post Link to post Share on other sites
Andy T 0 Posted January 16, 2007 Slight hissing at the back of the engine is normal, is the ISV damper (oval plastic box) as long as there's no air leaks or blockages inside, the noise is ok. Yes, MK3 VR6 ISV has same part number as Corrado VR, the part number is on this forum somewhere. Quote Share this post Link to post Share on other sites
ardandy 0 Posted January 16, 2007 http://cgi.ebay.co.uk/GOLF-MK3-VR6-IDLE ... dZViewItem I assume this should suffice? Quote Share this post Link to post Share on other sites
ardandy 0 Posted January 16, 2007 Can I also assume an idle control valve is the same thing as Idle Stabilisation Valve? Quote Share this post Link to post Share on other sites
Andy T 0 Posted January 16, 2007 ICV, ISV, ISCV yep all the same item. That pic of the ISV looks slightly different to mine and the mk3 one I bought for spares recently, I don't remember it having a black plastic outlet on it. Might be worth emailing them for the year/part no. then looking up the corrado number on here. 1995 Mk3's defo had the same part, maybe thats a later one? Quote Share this post Link to post Share on other sites
