coolrado
hard accelarator pedal with sqeek
a new cable wont hurt but it could just need a bit of light oil down the cable guide, also check the rubber bush that the end of the cable goes through on the pedal end, as they have a tendancy to wear through and wont let you reach full throttle.
Had same prob my 95 valver, tried oiling it with 3 in 1 oil, which worked ok for a while.
In the end just changed the cable, which cost arround £20 from VAG.
Had the same problem when i bought mine, tried oil and whatnot but in the end for the sake of £20 i thought i might as well change the cable
