poll250 0 Posted February 28, 2007 Hi, Does anyone know where the fuel cut off switch is located? We had a look at the garage trying to get my car started again and couldnt find it anywhere? Cheers, Andy Quote Share this post Link to post Share on other sites
flusted 0 Posted February 28, 2007 What engine Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted February 28, 2007 Think this will be his rear-ended VR6? Quote Share this post Link to post Share on other sites
poll250 0 Posted February 28, 2007 Yea sprry its a VR6 I forgot to mention! Quote Share this post Link to post Share on other sites
poll250 0 Posted February 28, 2007 anyone! Ive searched all over but cant find out how to get it running again to get it home! arghhh Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted February 28, 2007 there is no cut off switch on the corrado's. Quote Share this post Link to post Share on other sites
poll250 0 Posted March 1, 2007 Ive found info about a deceleration fuel cut off valve, is that not something to do with it? Basically straight after my crash the car wouldnt start at all ,and I was told it was probably because of a fuel cut off system or something? Any other ideas why it wont start? it doesnt even turn over, just nothing! Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted March 1, 2007 fuel cut of switch does just that and stops the fuel pump running,i would think you have a problem relating to the starter or a power / ignition switch fault. Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted March 1, 2007 The fuel pump relay requires a signal from the ECU (basically, an earth) in order to trigger. Check the earth on the relay. That is implemented as a crash-cut-off. The ECU drops its earth which would deactivate the fuel pump. Quote Share this post Link to post Share on other sites
poll250 0 Posted March 1, 2007 Cheers man, ill have a look for it when I get home tonight, the garage should be dropping it off later, just thought itd be better to having a running car for sale than a non-runner! Thanks again, Andy Quote Share this post Link to post Share on other sites
