RS VR6
Removed the cylinder head
Look at the gunk on the water passages!! Also the grooves in the timing chain tensioner.
The bottom of the head...again the passages.
See the nice trail of coolant coming out of the waterpump?
Whats going to be replaced:
Waterpump
Headgasket
New injector O-rings
Chains/tensioners
Valve seals
Lifters
Clutch with new main seal, flywheel bolts, throwout bearing
Cams (Schrick 260/264)
Various rubber seals: Crack pipe O-ring, T-stat seal
Car only has 120k on it.
What temps was she showing? Reckon she was pretty hot looking at that
would that not cause hot spots.? are there any hair line cracks any where. including pistons.
Actually the car runs fine. The coolant temps were nice and cool. The car never ran hot.
The headgasket was not leaking and the coolant was a few months old.
I was having the headgasket changed out along with the cam install. This is what was found after the head was pulled.
I'm assuming that all the buildup in the water passages are from the previous owner not using distilled water when mixing with the coolant.
using dilstilled water. oooh aren't you posh. my cars lucky if its gets pond water. he he
Speaking of valves...here thay are.
Clutch disk
Pressure plate
Throwout bearing...toasted!
Rusty water like that means neglect, no other reason, but obviously by the previous owner.
All VRs have localised corrosion on the block and head like that, it's a legacy of the old G11 days..... which is why VW revised the formula to G12+ in recent years.
Pistons and valves in excellent shape for the mileage.
