DUBST4R 0 Posted March 9, 2007 Hi, anyone who can gimme some sound advice?.. I have been reading comments etc. and the gist of what i have read is that if you lower your car by 40mm that shouldn't have a great affect on your ride quality.. I know from my experience; had Mk1 & Mk2 golfs if i dropped them by 60mm then you would more or less feel every bump on the road. Now i have recently dropped my Rado VR by 40mm (used Ventura TUV approved) springs (state a 40mm drop), but it really feels as though i dropped it excessively; is not comfortable at all to drive!!..i tried to bounce the suspension by hand at the front, but it doesn't budge... The drop looks perfect (not excessive) with the wheels but literally feel every bump on the road and this shouldn't happen with just a 40mm drop?? has anyone else experienced this?? Help would be appreciated!! Quote Share this post Link to post Share on other sites
Dogzyboy 0 Posted March 9, 2007 The general opinion with the Corrado is that you should change shocks & springs at the same time with a matched combination. By the sounds of it you've only changed the springs (correct me if I'm wrong)which more than likely is your problem. I believe the quality of components used also has a huge affect on the car. Quote Share this post Link to post Share on other sites
herisites 0 Posted March 9, 2007 What he said ^^^ if you have just put lower springs on then its bound to have a sh*t ride as the shocks aren't made for that height and so the rebounds etc will all be cocked up. You should change both shocks and springs together and as with most things you get what you pay for. Also did you cut your bump stops down??? If you lower the car by 40mm you should cut about the same off the bump stops otherwise the car will just be riding on them and you will feel every bump which sounds like the case. Quote Share this post Link to post Share on other sites
bustwell 0 Posted March 9, 2007 Ventura springs are known to give a harsh, bumpy and bouncy ride they are just nasty. They are fitted to my C by the previous owner and will be getting changed out for another setup this weekend!!! Quote Share this post Link to post Share on other sites
StuartFZR400 0 Posted March 9, 2007 DUBST4R, just a few points. I had mine 40mm low and also felt every bump, but that was partly due to running 17" rims. Confused? - dont be, what I mean to say is that the tyre also takes up some of the bumps in the road too and the 17" wheel requires a thinner (lower profile) tyre which will be stiffer and have less give. Moving onto the actual suspension, there are two parts that people mention. Basically the spring will compress and oppose the upward motion of the wheel (and your motion downwards). If you lower a car, you should really only compress to the same point. That is to say that if a standard spring were to move 100mm, then your springs should only move 60mm. To do this the spring should be firmer and therefore feel stiffer and move less and therefore feel harsher, but also MORE stable. Good or bad - you decide. Depending what spring you bought, will depend how stiff they are. As for the shock, this opposes the spring (car moving back upwards), ie when the wheel moves out and away from the arch. If you had no shock or a very weak one (like those silly yanks), you'd find the spring forces your car back up too quickly. A stronger (lower) spring will force you up quicker and therefore people often change the shocks too so as to compensate for this. Once the car has sprung back up in a nice slow motion, it should stay there and not bounce down an inch or two - so for example when you bounce on your bonnet you would expect the car to come up once and not up-down-up (ossolate). The shock should not resist the initial bump. HTH in addition with herisites comment. Quote Share this post Link to post Share on other sites
steve @ 0 Posted March 9, 2007 Its the springs, Ventura are pretty pants tbh very harsh. Get your self some PI springs. Quote Share this post Link to post Share on other sites
StuartFZR400 0 Posted March 9, 2007 ps - dont forget to get the camber set up too; it'll tramline like a fekker if not. Quote Share this post Link to post Share on other sites
MK1Campaign 0 Posted March 9, 2007 You get what you pay for with suspension. Just changing the springs will never give a good ride. The factory springs arent designed to be compressed that much. Quote Share this post Link to post Share on other sites
2cc 0 Posted March 13, 2007 Have to agree with Steve@. I've got PIs and Koni TAs on both mine; the ride is great, especially good on the VR. Quote Share this post Link to post Share on other sites
DUBST4R 0 Posted April 4, 2007 Thanks guys for your advice.. will be looking at changing the set up...So the PI springs are good combi with Koni shocks?.. Quote Share this post Link to post Share on other sites
herisites 0 Posted April 4, 2007 Yes the PI and Koni combination has been highly rated by a few members on here for ride comfort and a lot of guys go for H&R and Koni but i believe the PI springs drop a bit more than the H&R's. Quote Share this post Link to post Share on other sites
Goldie 2 Posted April 4, 2007 How far do the PIs put the car down... I had a look at someones 40mm drop the other day and i quite fancy going a little further than that without decking the thing... Quote Share this post Link to post Share on other sites
Dogzyboy 0 Posted April 4, 2007 How far do the PIs put the car down... I had a look at someones 40mm drop the other day and i quite fancy going a little further than that without decking the thing... Me & you both Goldie. Still holding off buying the new sus as I dont wanna buy 40mm & it still be too high! Can't afford coilies just now, so Koni Sport Kit is looking like my plan at the mo. Quote Share this post Link to post Share on other sites
Goldie 2 Posted April 4, 2007 I dont wanna buy 40mm & it still be too high Thats exactly how i feel.. Im in the same boat with the coilies, cant really afford so always on the look out for second hand ones. The obvious advantage with them though is being able to decide when you are happy with the height.. Quote Share this post Link to post Share on other sites
chrishill 0 Posted April 4, 2007 40mm (used Ventura TUV approved) springs just to back up what others have said, I had the 'lovering kit' that euro car parts sell which is bilstein dampers and ventura shocks and it was bloody horrible for rebound and being crashy. I dont wanna buy 40mm & it still be too high! IMO -60mm is the best looking ride height, wheels fit the arches just right and there's not too much scraping of the front spoiler. Quote Share this post Link to post Share on other sites
Goldie 2 Posted April 4, 2007 What are you running on yours chrishill, suspension and wheels?? Quote Share this post Link to post Share on other sites
chrishill 0 Posted April 4, 2007 well nothing now, I dont have one anymore :'( on my valver I had 16" borbets with the ventura setup which was bouncy, not low enough and generally a bit poo on the VR I had 17x8 RH's and Koni -60mm springs/shocks and the ride was a little bumpy but only what you'd expect from a lowered car, handled great! http://www.chris-hill.co.uk/photos/Corrado%20VR6%20-%20%20RIP%20/DSCF2067.jpg shows the ride height of the VR quite well at -60mm (massive image!) Quote Share this post Link to post Share on other sites
Goldie 2 Posted April 4, 2007 well nothing now, I dont have one anymore Thats a shame, i was going to ask if i could come a have a look.... Quote Share this post Link to post Share on other sites
chrishill 0 Posted April 4, 2007 you'd have been welcome to :lol: Quote Share this post Link to post Share on other sites
DUBST4R 0 Posted April 9, 2007 I have just been looking around and noticed you can get a Jamex Coilover kit for around £260 inc. P&P..or another german manufactured brand with the TUV approval for approx. £230.. But as we know Coilover kits normally start at £400plus..does this mean the Jamex kit is not that good?.. Quote Share this post Link to post Share on other sites
