jack
New Radiator
Hi folks, I just found out tonight that I need a new radiator :( for my VR6. Does anyone have any suggestions/recommendations on a particular brand or should I just go for a factory one.
ND (Denso) Marsdon - UK made part but only seem to be available thru VAG...
Could try speaking to them tho - based in Shipley near Bradford.
personally always go for a VAG one got mine for £122 quid when mine went big ish job but can be done yourself and you'll save on labour costs!
Would advise against a GSF radiator. Recently fitted one to mine (branded "Flusser") and its leaking coolant from two places at the moment. As soon as I can afford to get it out and buy a VAG one I will be doing so!
I'll second that, have the same problem as jim in at least one place, can I get the temp switch to seal?...no.
Thirded. GSF rad didn't sit in the crossmember dimples properly, as such kept popping out of one side despite being clamped at top by slam panel!
Glad thats not just me then. Eric wrapped the temp switch with plenty of PTFE tape but it still dribbles out of the bottom of it.
Sigh.
Lots of poorly designed / manufactured radiators from GSF it seems!
I found the plastic pipe at the top for the cylinder head hose to be porous too, seemed to be a fair bit weaker than my original rad.
Thanks for the advice, from the sound of things I'll be staying clear of the GSF and going to my local VW dealer.
Which dealer was that?
My mate works at VW and quoted me £153 at that was with 18% discount.
I believe the book figure is £163+Vat. Just replaced my non gen rad with a new gen item. Miles better in terms of quality.
I just ordered one today from Heathrow VAG and it cost me £160 + VAT. Tried to get them to discount it but they weren't going to budge on the price.
it should be easy to change yourself
Spent an hour and a half this evening removing the old radiator ready for the arrival of the new one. didn't use the bumper/slam panel removal method but just unbolted the fans from the radiator first, removed them and then removed the rad. You have to remove the battery first, the N/S headlight/grille and apply some gentle upwards pressure on the top of the slam panel but it will come out with a bit careful manoevring.
I've decided to change the thermostat and housing whilst I've got the coolant drained, no doubt it's gonna give up at some time seeing as it's nearly 12 years old!
Lol looks like i got my rad at the right time then i got mine off a mate who works for audi (same group as VW) and he got the discount aswell! Asked him to sort me one out and phoned me back later and said its going to be pricey so when he told me £122 quid i was more than happy! Must vary from which part of the country you get it from!
Was just interested about this and started doing a bit of Googling and it turns out that Denso have an office in Coventry.. just across from that Nando's where we always go just off the M6! Take a lookie at the bottom:
http://www.denso-europe.com/uploads/Rou ... p_DSUK.jpg
I put a post up in the suppliers thread. Picked my new vr radiator up for £99.87 all in, from a radiator specialist near me. They fitted the top elbow and temp sender and pressure tested it in front of me. Looks OE quality too.
