Rob_B
kangaroo G60
morning, just thought i would ask, see if someone could help me cure this annoting problem..
when you hold the throttle on the G60 at low revs, the revs then drop (throttle still in the same position) then pick up again. it will do this a few times. now this is not on idle, its on part throttle, ie 1500rpm. this will in turn make the ride really jumpy at low revs. has anyone solved this problem before, its really getting on my nerves as it makes the drive really crap. you either have to gun it or not be on the throttle!
got no hair to tear out now, so please help!!
rob
i could give it a go. i did wonder if there was enough fuel pressure there? any more suggestions guys and gals?
it was but steve couldn't sort it out. so im not sure whether its a mechanical issue or map problems. i can't imagine im alone in having this problem so i wondered how it was sorted or actually what the problem is. any ideas darren?
