John-M
Speedometer / Rev counter correlation - readings wanted
I'd be very gratefull if anyone with a late (94/95) VR with standard gear ratios and standard wheels/tyres would post the following details for me, please :-
Speedo reading at 1,000 rpm in 5th
Speedo reading at 1,500 rpm in 5th
Speedo reading at 2,000 rpm in 5th
Speedo reading at 2.5000 rpm in 5th
and any greater rpm figures you are able to get - om private roads of course !!
In case you are wondering why, my indicated speed at 2,000 rpm is NOT twice that at 1,000 and there seems to be some inconsistencies :(
Most puzzling - any observations welcome.
Does anyone know what the speed per 1,000 in 5th is 'supposed' to be ?
J
Yes I can.
The 24V engine seems more flexible low down. But it has replacement instruments and I'm not completely sure about their accuracy, hence the request for other forum menbers' readings.
Can anyone post their readings, please ?
If I move my car later I'll have a look to see what the speeds are I'm getting at the various RPM's.
The main problem you're likely to find is that most speedos are not 100% accurate, mine is about 3-4% out out different speeds (checked with Sat-Nav) but to give you a starting point I happen to know (don't ask me how! :lol: ) that if you've got a standard VR gearbox and standard wheels you should be doing 70mph at 3100rpm.
just been out in car, 1995 VR6, totally standard 153,000miles
1000rpm = 26mph
1500rpm = 37mph
2000rpm = 49mph
2500rpm = 60mph bang-on!
3000rpm = 72mph
thats all i could remember as i didn't have a pen :lol:
Thanks for the posts.
I'll double check my readings and post them so you can see why I'm a wee bit concerned that something aint right :(
Feed the gearbox ratios into the wiki article here to see what you should be getting.
Calculator is at bottom of article.
