Setone 0 Posted November 13, 2007 Thermostat on a G60 Corrado how long will it take me to do? What the best way to tackle it? charger out or bumper off, or both? Cheers Paul Quote Share this post Link to post Share on other sites
kongo127 0 Posted November 13, 2007 Hi mate! I Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted November 13, 2007 Ive got a VR6 so not much help but replace as much as you can while your in there! Quote Share this post Link to post Share on other sites
Goldie 2 Posted November 13, 2007 DanVW did this lot on his G not long ago Paul, hes along in Southampton, may be worth having a chat with him... Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted November 13, 2007 i did this last week. I put the car on axel stands and then took front bumper off. Just made life so much easier when I was draining the system in regards to getting access. No pi$$ing about. I also unbolted the pas pump and tie wrapped it out the way to give access to the screws on the plastic housing where the t'stat lives. No need to touch the charger IMHO. Simple job just about making room for yourself to work. Quote Share this post Link to post Share on other sites
Setone 0 Posted November 14, 2007 great cheers guys, don't really want to remove the charger so i'll take the bumper off route Quote Share this post Link to post Share on other sites
DanVW 0 Posted November 14, 2007 One thing to watch out for is the "hidden bolt" on the PAS pump bracket :lol: once you have slackened off the PAS belt and removed all the bolts you can see get your small socket extension bar with a *10mm (iirc) socket on and feel about above the bracket (where you cant see!) untill you feel the bolt head, whip that sucker out and you will see the plastic Thermostat cover. Two small bolts and its off swap in your new Stat with a new rubber o-ring and re-assemble job done :) give us a PM if you get stuck or have any further questions Cheers Dan Quote Share this post Link to post Share on other sites
Setone 0 Posted November 17, 2007 well the job only took me about 2 hours, didn't remove the bumper or charger, just removed the power steering pump, when i removed the housing was shocked to find there was no thermostat fitted!!! anyway its all back together run up to temp, no leaks on air locks, just wish i had picked a better day to do it, got soaked by the rain lol Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted November 17, 2007 good job. well done for doing it in this weather. :) Quote Share this post Link to post Share on other sites
