joby 0 Posted January 20, 2008 As im on a mission replacing all the bushes underneath the corrado I was thinking while everything was stripped why not sort the puny brakes on the 1.8 16v with VR6 items and was wondering what was involved? Is it just a matter of carriers, calipers and discs or should you replace the master cylinder too! Im replacing the rears (standard) at the moment along with the rear Axle bushes which i completed yesterday :D Cheers All ! Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 20, 2008 Is it just a matter of carriers, calipers and discs that should do it, you can get away with the narrower 16v calipers but pads may need trimming down when pads and discs are new as the G60 280mm discs are slightly thicker as are g60 pads and so the caliper itself is wider. Mk3 golf GTI 280mm calipers and carriers will do too, just not the later 288mm ones as you can't get 288mm 4 stud discs. Quote Share this post Link to post Share on other sites
nocrap 0 Posted January 20, 2008 G60s are what you need not VRs.....VRs are 5 stud and you'll need 4, unless you're changing hubs as well? Quote Share this post Link to post Share on other sites
Toad 0 Posted January 20, 2008 The VR6 and G60 calipers and carriers are the same items, it's just different disks you need. Quote Share this post Link to post Share on other sites
nocrap 0 Posted January 20, 2008 Cheers Toad, thats what i meant....had the word disks in my head it just didn't make it onto the keyboard! Quote Share this post Link to post Share on other sites
joby 0 Posted January 20, 2008 Ok So its G60 or VR6 Carriers and callipers and then 280 mm discs ! But not 288 cos they dont do them in four stud :) Ok Thanks everyone.... Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 21, 2008 Ok So its G60 or VR6 Carriers and callipers and then 280 mm discs ! But not 288 cos they dont do them in four stud :) Ok Thanks everyone.... yeah, avoid any calipers and carriers (from a mk3 golf) that are marked 'ATE' - these are the 288mm ones and a totally different type. You need Girling ones from a pre 95 mk3 golf GTI 8v, 16v or VR. or passat 2.0 16v(1994-6) or passat VR6 Quote Share this post Link to post Share on other sites
The Hub 0 Posted April 24, 2008 Ok So its G60 or VR6 Carriers and callipers and then 280 mm discs ! But not 288 cos they dont do them in four stud :) Ok Thanks everyone.... yeah, avoid any calipers and carriers (from a mk3 golf) that are marked 'ATE' - these are the 288mm ones and a totally different type. You need Girling ones from a pre 95 mk3 golf GTI 8v, 16v or VR. or passat 2.0 16v(1994-6) or passat VR6 I recently bought a set of G60 Calipers and Carriers which are made by Lucas. Now I was told this was ok so long as they are Lucas or Girling and stamped with with a 54. Well turns out when I had a wheel off tonight the Caliper and Carriers that are on the car are Girling ones stamped with a 54 :nuts: The discs are definately 256mm as I offered up the 280mm ones and they are noticeably larger. Is it possible the calipers and carriers have already been upgraded but the old owner left the the smaller disk on, I can't see how the 280mm items would fit. Any suggestions anyone? Quote Share this post Link to post Share on other sites
joby 0 Posted April 24, 2008 No mate, When i got my secondhand 280mm calipers and carriers i thought the same, same 54 on them they looked identical but when you take them off the diference is clear :) the G60 caliper is wider and the carrier bigger.. Quote Share this post Link to post Share on other sites
The Hub 0 Posted April 24, 2008 Cheers for that mate, thought they look slightly different, but thought it might have just been the different makes. :salute: Quote Share this post Link to post Share on other sites
robdriver 10 Posted March 29, 2013 I bought what I thought was a set of 280 front calipers and carriers .... when i took my wheels off to install them they looked exactly the same as what was there.. Lucas 54 marked and I took the pads out of both and offered them against each other....exactly the same size So I put the pads back in and decided I was ripped off by seller I have a 2.0 8v with 256 size fronts in place I am now thinking of putting on the double piston Girling 60's and researching the correct master cylinder size....any suggestions Quote Share this post Link to post Share on other sites
Craig 0 Posted March 29, 2013 Bit of a thread resurrection :) not sure on what calipers you have bought. I have a set of 280 calipers and carriers off my vr6 when I upgraded to 312s :) Quote Share this post Link to post Share on other sites
robdriver 10 Posted March 29, 2013 thanks for the offer... i think they are 5 stud bolt pattern though.......I am rather keen on the Audi S2 double pot upgrade and will continue researching them cheers Rob Quote Share this post Link to post Share on other sites
davidwort 0 Posted March 29, 2013 I bought what I thought was a set of 280 front calipers and carriers .... when i took my wheels off to install them they looked exactly the same as what was there.. Lucas 54 marked and I took the pads out of both and offered them against each other....exactly the same size So I put the pads back in and decided I was ripped off by seller I have a 2.0 8v with 256 size fronts in place I am now thinking of putting on the double piston Girling 60's and researching the correct master cylinder size....any suggestions G60 pads are the same size, just a little thicker and the calipers a little wider in the jaws, the only obvious difference is the greater offset of the g60 carriers for the 280 discs. Quote Share this post Link to post Share on other sites
willmason1975 10 Posted April 25, 2013 I had the twin pot calipers on my old valver with G60 discs. They are a very good upgrade brakes were very responsive. Only drawback I found was the pads were £65 Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted June 2, 2013 Something to consider: New discs, pads, hoses and fluid will give you surprisingly good brakes, regardless of size. If you do track days, bigger discs will be more fade resistant but that's it. I mention this as the most surprisingly good-feeling brakes on any of the 5 Corrados I've owned resulted from fitting new genuine parts to one of the G60s. This despite running 288mm and 312mm set ups on a VR6, and a set of Ibiza Brembos on the 16v (which were mind blowing when warm...). ---------- Post added at 7:52 PM ---------- Previous post was at 7:50 PM ---------- Something to consider: New discs, pads, hoses and fluid will give you surprisingly good brakes, regardless of size. If you do track days, bigger discs will be more fade resistant but that's it. I mention this as the most surprisingly good-feeling brakes on any of the 5 Corrados I've owned resulted from fitting new genuine parts to one of the G60s. This despite running 288mm and 312mm set ups on a VR6, and a set of Ibiza Brembos on the 16v (which were mind blowing when warm...). Quote Share this post Link to post Share on other sites
