mariojoshi 1 Posted March 4, 2008 Well guys and gals.. Like most of my posts.. it does exactly what it says on the tin. I've found a random connector hanging down on the drivers side of my engine bay.. just below my chin spoiler. It's blue.. (usually meant temp related on my old polos) with a grey attachment... (which is not a bulb holder) The loom for it goes back up into the bay, round the drivers wing and into the large metal cylinder in the centre of the bay on the bulkhead at the back (I think) What in name of all things VW is it? I can't find anything around it that it could possibly plug into! Sorry it's not the most informative pic in the world.. awkward position. The grey attachment defo has two metal connectors inside it so I guess it's not just a blank. It has a central plastic prong on the inside on the other end, so I assume it's not actually an electrical connection there.. but maybe a sensor?! HELP! Many thanks! Josh Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 4, 2008 Thats the outside air temp sender - should be mounted either on the brake cooling duct if fitted or the lower bumper grill Quote Share this post Link to post Share on other sites
JMC 0 Posted March 4, 2008 Yep, the grey bit is the temperature sensor. Of course if you're like me, you've relocated it to a cold air feed coming up where the carbon cannister used to be (on my G60) to monitor air temps coming into the air box :D Quote Share this post Link to post Share on other sites
mariojoshi 1 Posted March 4, 2008 Guys! You've really given me a bit of peach of mind. I was a bit worried earlier! This is the first car I've had with the MFA setup, so it didn't click. JMC - you sir, are a legend! What a clever idea! Quote Share this post Link to post Share on other sites
swiftkid 1 Posted March 6, 2008 next up for guess that wire... brown wire with spade connector, comes in the engine bay with the loom just behind the metering head. when i touch it to metal it turns the fan on. fan works fine, even have a switch on the dash to manually turn it on. no idea what the wire is meant for though. Quote Share this post Link to post Share on other sites
Dec 1 Posted March 6, 2008 That should connect up to a small thermo switch at the front left side of the rocker cover. The spade connection can snap off them, so it may need to be replaced. It basically controls the fan over-run to keep the fan going for a few mins after you turn the engine off :wink: Quote Share this post Link to post Share on other sites
flusted 0 Posted March 6, 2008 yep as dec says, its for fan over run when you stop engine Quote Share this post Link to post Share on other sites
pbradley98 0 Posted May 11, 2008 Thanks for pointing out what this is - my temp sensor just seems to have dropped off my MFA after the radiator was replaced, so given it looks like it's right next to the radiator was probably knocked loose whilst fitting! Cheers Phil Quote Share this post Link to post Share on other sites
boost monkey 0 Posted May 11, 2008 Note to self: You also need to reconnect this to it's rightful position!:drinking: Quote Share this post Link to post Share on other sites
timg60 0 Posted May 11, 2008 I am ok on the engine bay front but think there should also be a " Name that random wire/connector flapping around by my fuse box thread " :grin: Ive got millions. Might post a photo tomorrow to give everone a laugh :ignore: Quote Share this post Link to post Share on other sites
